PWM NOT WORKING
Alkaline
Has thanked: 42 times
Been thanked: 41 times
PWM NOT WORKING
Post by Alkaline »
Hi everyone
I'm trying to use the pwm without success.
The output pin always remains low as if it was not enabled.
I'm using the example available here https://www.matrixtsl.com/wiki/index.ph ... 9ba088505c
I'm using a pic32mx470f512h
Greetings
Update
The pwm only works on chanel 1. If I try to change the channel always keeping the timer 2 the pwm stops working.
PWM_fader.fcfx
(8.84 KiB) Downloaded 262 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: PWM NOT WORKING
Post by QMESAR »
Hi.
First off all you have to make sure your configuration settings are correct
(1) mcu is running
(2) running at the correct speed
Secondly as the PIC32 PWM makes amatch between the Duty set value and the value the Timer PR register is loaded with I would use the
setDuty10 parameter ,I have done this in your Flowchart and you will see the PWM in the simulation is active
Hope this helps
check your configbits they look abit strange to me
PWM_fader.fcfx
(8.87 KiB) Downloaded 249 times
QMESAR
Re: PWM NOT WORKING
Post by QMESAR »
I just compiled the Fowchart and programmed a uC32 board with your Flowchart
and the PWM is working just fine using the setDuty10 function :D
Counting up and down
Alkaline
Re: PWM NOT WORKING
Post by Alkaline »
Hi Qmesar
Thanks for the reply.
Yes, checking the configuration of this project is totally wrong.
the settings that I usually use are as follows.
The program now works correctly but only on channel 1.
If I try to change channels, the pwm will not work
QMESAR
Re: PWM NOT WORKING
Post by QMESAR »
Hi.
Ok I will try on my uC32 board and see what I get sometime today . :D
QMESAR
Re: PWM NOT WORKING
Post by QMESAR »
With me Channel 1 and 2 are working :D
Did you use a second PWM enable icon and enable PWM2 ?
PWM_uc2.fcfx
(10.82 KiB) Downloaded 280 times
Alkaline
Re: PWM NOT WORKING
Post by Alkaline »
Hello Qmesar
I'm sorry for the delay, but I had to finish a project.
Today I tried again to run the software but I still have problems with the channel other than 1.
The pwm works correctly on channel 1.
In the next days I continue to investigate because it is very strange.
QMESAR
Re: PWM NOT WORKING
Post by QMESAR »
Hi ,
:D
OK no problem at all please report your findings as I am not using the exact same chip as you .
I would have liked to test on the same chip but I do not have one .
Good luck
Re: PWM NOT WORKING
Hello Alkaline,
Did you manage to get anywhere with this?
Alkaline
Re: PWM NOT WORKING
Post by Alkaline »
Hi Benj
sorry for the wait but I had to spend some time on other projects.
Anyway the pwm works correctly!At the beginning I had a little bit of difficulty in understanding how the flowocode set the various parameters but then I solved it!
On another subject, the program i'm completing is very large, how can I know exactly how much space it holds in memory? Do I need to enter any commands in the compiler?
now to calculate the program memory I convert the reported value
"program memory: start address = 0x1d000000, end address = 0x1d0407ff"
d0407ff = 264,191 bytes, is it right?
Thanks in advance
Re: PWM NOT WORKING
Looks right to me.
