PIC18F25Q10 and PIC18F27K42 - No Timers work
ronaldlijs
Has thanked: 20 times
Been thanked: 25 times
Post by ronaldlijs »
Hi guys,
It seems no timers work at all when configured in Flowcode for PIC18F25Q10. I've tried Timer 0, Timer 1 and Timer 2 with the same results.
There is nothing else in the code, just enabling any Timer causes the code not to compile. All other code on my program works fine at the moment.
When compiling the output shows:
PIC2_PLAYER1_TEST.c: main()
    91:	T0CONbits.T0CS = 0;
	^ (192) undefined identifier "T0CONbits"
	               ^ (196) struct/union required
    92:	T0CONbits.T0SE = 0;
    93:	T0CON = (T0CON & 0xF0) | 0x08;
	^ (192) undefined identifier "T0CON"
    95:	INTCONbits.TMR0IE = 1;
	                  ^ (255) not a member of the struct/union ""
	                     ^ (182) illegal conversion between types
int -> volatile union S1339
PIC2_PLAYER1_TEST.c: myisr()
   111:	if ((INTCONbits.TMR0IF) && (INTCONbits.TMR0IE))
	   (255) not a member of the struct/union "" ^
	                  (199) logical type required ^
   114:	INTCONbits.TMR0IF = 0;
(908) exit status = 1
It's strange as this chip has got a total of 7 timers and not all of them are shown on the "Interrupt on" Flowcode list
  • Three 8-Bit Timers (TMR2/4/6) with Hardware Limit Timer (HLT)
    Four 16-Bit Timers (TMR0/1/3/5)
I have the same error with PIC18F27K42:
Flowcode1.c: main()
    90:	T0CONbits.T0CS = 0;
    91:	T0CONbits.T0SE = 1;
    92:	T0CON = (T0CON & 0xF0) | 0x08;
Could it be that the configuration fcdx file for these chips is wrong? For this project we also use PIC18F25K50 and PIC16F15345 and we have had no problems with these.... I am unable to use any new chips as these 2 were listed as being compatible with Flowcode 8 :-(
I have checked the Data Sheet and it seems the register should be T0CON0 and not T0CON
Data Sheet Timer0
Data Sheet Timer0
The code generated by Flowcode is:
	cr_bit(T0CON, T0CS);
	cr_bit(T0CON, T0SE);
	st_bit(INTCON0, GIE);
	st_bit(PIE3, TMR0IE);
If edit the C code generated and change the timer section to:
	T0CON0 = 0x80;
All compiles fine... 0x80 is 10000000 enables Timer 0 as 8 bit timer and sets postscaler to 1:1.
I am no C programmer in any way (this is why I use Flowcode), but I feel there is a bug here with Flowcode not generating the correct code maybe?
Help would be appreciated as can't do much on my project without a Timer on both MCUs :-(
Thanks in advance for your kind help!
R
Re: PIC18F25Q10 and PIC18F27K42 - No Timers work
Just investigating this for you now. You're right that it's probably a chip definition related issue. Should hopefully be a quick fix.
I'm away from my desk today but here are fixed definitions for the devices you mentioned.
Simply copy into your "C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC" directory and restart Flowcode.
I'll get the fixes pushed to the update system for you tomorrow.
18F25Q10.fcdx
(38.96 KiB) Downloaded 330 times
18F27K42.fcdx
(46.76 KiB) Downloaded 317 times
ronaldlijs
Hi Ben!
I've been away for a few days, just came back today...
MANY thanks for your prompt reply, will give these files a try and let you know the results.
Best regards,
R
ronaldlijs
OK, for PIC18F25Q10 tried with only 1 Timer enabled at first and nothing else in the code:
PIC2_PLAYER1_TEST2.c: main()
    90:	T0CON1 = (T0CON & 0xF0) | 0x00;
Seems the entries on the list are still a bit messed up... there are some duplicates there:
For the second PIC18F27K42, I've enabled All 3 timers and the UART RX0 timer and it compiles fine! :D
Thanks for your help!
Many thanks for letting me know.
These should both be fixed now with the latest definitions available via the update system.
ronaldlijs
Thanks Ben, great stuff. I've updated Flowcode now (full detabse) and restarted.
The list for PIC18F25Q10 looks good now (thanks):
However when compiling I get:
   102:	PIE0bits.TMR0IE = 1;
int -> volatile union S149
   125:	if ((PIR0bits.TMR0IF) && (PIE0bits.TMR0IE))
   128:	PIR0bits.TMR0IF = 0;
int -> volatile union S176
Thanks again!
R
What device do you get the compile error on. I can't seem to replicate this here on the Q10 devices.
Maybe I'm using a more up to date version of the XC8 compiler?
Aha, I have replicated on the K42 devices. Fixing now.
ronaldlijs
Device is def PIC18F25Q10 28 pin SO package.
Interesting that I am just now trying some RS485 interrupt routine on PIC18F27K42 (the peer to the Q10 master I'm using) and I get a similar error:
This was whilst enabling UART interrupt on receive... with minimum code, just a timer and the RS232 ReceiveByte function...
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_1()
   408:	TXSTAbits.BRGH = 1;
	^ (192) undefined identifier "TXSTAbits"
   411:	SPBRG = (((19660800 / (9600)) - 8) / 16);
	^ (192) undefined identifier "SPBRG"
   412:	RCSTA = 0;
	^ (192) undefined identifier "RCSTA"
   423:	RCSTAbits.SPEN = 1;
	^ (192) undefined identifier "RCSTAbits"
   426:	TXSTAbits.TXEN = 1;
   429:	RCSTAbits.CREN = 1;
   437:	PIE1bits.RCIE = 0;
int -> volatile union S151
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Uninit_1()
   708:	RCSTA = 0;
   709:	TXSTA = 0;
	^ (192) undefined identifier "TXSTA"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Send_1()
   788:	TXREG = nChar;
	^ (192) undefined identifier "TXREG"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Receive_1()
   901:	regcheck = (PIR1bits.RCIF);
volatile union S178 -> unsigned char
	                          ^ (181) non-scalar types can't be converted to other types
   949:	regcheck = (RCSTAbits.FERR);
   952:	dummy = RCREG;
	        ^ (192) undefined identifier "RCREG"
   959:	regcheck = (RCSTAbits.OERR);
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: 962: too many errors (21)
Error returned from [xc8.exe]
I am sure you'll get to the bottom of this, let me know please if you need anything else from me.
I had tried last week the latest XC8 compiler I downloaded last week as from a previous thread of yours you mentioned this could be the issue... but with same results... so reverted to the FC8 one:
C:\Program Files (x86)\Microchip\xc8\v2.05\bin>xc8
C:\Program Files (x86)\Microchip\xc8\v2.05\pic\bin\picc
Microchip MPLAB XC8 C Compiler V2.05
Build date: Dec 20 2018
Part Support Version: 2.05
Copyright (C) 2018 Microchip Technology Inc.
(880) invalid number of parameters. Use "XC8 --HELP" for help
Regards!
R
ronaldlijs
I was wondering if there were any more news on this one?
Thanks!
R
I'm looking into the problem for you. It's a substantial change from the usual UART register setup so I'm going slowly to try and avoid creating more problems down the road. Hopefully have a fix for you shortly.
ronaldlijs
Thanks Ben,
Don't spend any more time on this as we are have decided not to use any of these 2 MCUs (and also PIC16F15325 which we were having an interrupt problem as well with) and will be replacing them with PIC18F26K40 which seems to compile well and will simply redesign all our boards to use this MCU.
Plenty of RAM, program memory, EEPROM and most importantly PPS which I've used on the dsPIC33 devices and it's great Micrchip feature! This MCU has got also many timers and even internal 64MHz clock if needed, only at like over £1 each, so great stuff.
Many thanks for your efforts and keep up the GREAT work you have been doing over the past years!
R
