Add extra internal clock config stuff to PIC 12f1501 ( Use the Internal Ocillator Helper)
chad
Has thanked: 27 times
Been thanked: 33 times
Post by chad »
* EDIT See above posts!
Hey, Just got the PIC8 Pack and I am playing with the chip and it looks like there are some config bit missing from the configuration.
Thanks,
Chad
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Add extra internal clock config stuff to PIC 12f1501
Post by QMESAR »
Hi.
Not sure what you are missing however the chip support 4 modes for Clock settings all 4 are available in FC
chad
Re: Add extra internal clock config stuff to PIC 12f1501 (found it)
Post by chad »
Hey, I found that. What I couldn't find was the Internal Oscillator Helper. Got it all going.
I have another problem now but I will post that elese ware.
Chad
QMESAR
Post by QMESAR »
If you are looking to set the internal OSC at different speeds
(1) place a INTOSC helper on the 3D panel,then open properties set the clock speed you want (I used 16Mhz here)
You will see a value for the OSCCON register in the properties now place a C icon at the beginning of your Flowchart and enter this value in a call
as I show here and now compile your chart and the chip will run at your selected Internal OSC frequency
QMESAR
Post by QMESAR »
Glad you found it while I was making this post :D
chad
Post by chad »
Thanks, I remembered seeing it a while back. It seems like that should be just built into the configurator?
I just posted a little pwm issue.. On to the next thing. . .
Yet another new chip;)
Chad
