PIC18F87K22 RC0 - RC1 not work ! [Solved]
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
xelites
Been thanked: 7 times
Post by xelites »
hello Benj, use the pic 18f87k22 but RC0 and RC1 doors do not work! I enclose simple blink program. the problem is that even changing the configuration bits (bit32 and bit 40) as in Bit set file in attached the result does not change and does not work for me even the PWM configurations of these pins. Thanks await feedback
Gabriele
Motus_test.fcfx
ex. program
(7.57 KiB) Downloaded 670 times
file bit config
(134.91 KiB) Downloaded 580 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: PIC18F87K22 RC0 - RC1 not work !
Post by LeighM »
I think your "SOSC Power Selection..." needs to be set to Digital, not SOSC circuit selected
xelites
Post by xelites »
Now I try
xelites
Post by xelites »
yess :-) ok problem solved thanks very much
xelites
Post by xelites »
You can remove the post LeighM I thought it was a bug sorry
Good job everyone
dannyvanneijenhoff
Has thanked: 17 times
Been thanked: 10 times
Re: PIC18F87K22 RC0 - RC1 not work ! [Solved]
Post by dannyvanneijenhoff »
here is another setting for PWM on C1
(4.8 KiB) Downloaded 1366 times
