hello Benj, use the pic 18f87k22 but RC0 and RC1 doors do not work! I enclose simple blink program. the problem is that even changing the configuration bits (bit32 and bit 40) as in Bit set file in attached the result does not change and does not work for me even the PWM configurations of these pins. Thanks await feedback
Gabriele
PIC18F87K22 RC0 - RC1 not work ! [Solved]
- Motus_test.fcfx
- ex. program
- (7.57 KiB) Downloaded 668 times
- file bit config
- (134.91 KiB) Downloaded 580 times
Re: PIC18F87K22 RC0 - RC1 not work !
You can remove the post LeighM I thought it was a bug sorry
Good job everyone
Good job everyone
dannyvanneijenhoff
- Has thanked: 17 times
- Been thanked: 10 times
