Problem with the PIC16F648 ADC
The high-case ADC "ADRESH"is not read.
Previously, everything worked and now it doesn't .
When using macros (Flowcode) everything works but the program
remains in interrupts while the ADC is running and this is 100-200 uS
lose time . You can return for the result in interrupts.
Please make an ADC interrupt macro!!!
Sincerely, Osta.
File attached
Sincerely, Osta.
File attached
- IMG
- ADC.jpg (58.57 KiB) Viewed 10394 times
- ADC.fcfx
- prog
- (26.18 KiB) Downloaded 323 times
Re: Problem with the PIC16F648 ADC
I thinkt he problem was your interrupt enable code. You were using bit names such as GO = 1 whereas this should have been ADCON0bits.GO = 1
I've made some changes to your program inside the interrupt enable icon, hopefully it will improve things for you.
Also I've noticed your if statement had been converted to C with customised code to add a { after the decision. This should not be required but i've left as is as it doesn't seem to be causing issues in the generated code.
Hi Benj!
It doesn't change anything...
My version of the program works
only if I read lowercase,
I attached a photo below.
Sincerely Osta
Sincerely Osta
- Oscil
- ADC.jpg (248.2 KiB) Viewed 10377 times
- ADRESL
- ADRESL.jpg (62.62 KiB) Viewed 10377 times
Hi Benj!
I apologize for making a typo.
I use the PIC16F684 controller
Hi Benj!
Your recommendation doesn't work!
As before, the senior level is not readable.
Only the lower-level ADC is read.
Above is a picture of the lowercase operation
What to do?
What to do?
Hi Osta,
You have set the ADC to be Right justified which means that the majority of the ADC result will reside in the ADRESL register (ADFM = 1).
Maybe this should instead be (ADFM = 0).
ADCON0 = 137; // Настройка АЦПаCode: Select all
ADCON0 = 9; // Настройка АЦПаRegards Ben Rowland - MatrixTSL
Рш Benj
That's right, I need to move to the right.
otherwise, I will have to do an extra operation-shift the entire result by 6 bits
When the ADC is shifted to the right, it is 768
the first two bits must be used in upper case.
- ADRESH
- ADRESH.jpg (62.04 KiB) Viewed 10338 times
The macro does this.
And I need to start the ADC and get out of interrupts as soon as possible.
Go back for the result, change the channel and exit again. This is a cycle that takes less time
, measurements run in parallel and there is no reason to wait for the result in interrupts.
- Code snippet
- Безымянный.jpg (87.9 KiB) Viewed 10334 times
Hi LeighM
The macro works fine!
I can't count the upper case
when shifting to the right .
Hi LeighM
I did all three options the result is the same.
- ADCON1
- ADCON1.jpg (86.03 KiB) Viewed 10300 times
This is the same solution implemented in Flowcode 6
and it works.
I did the same in Flowcode 7.
and it works.
- FC6
- FC6.jpg (53.64 KiB) Viewed 10297 times
Hi LeighM
I still have the old FC6 file and the new FC8 file
in FC7 it is lost but I installed FC7 yesterday and tried IT
it doesn't work either.
That may be so.
Well, if you can take that into account.
I can't change the controller
this is an old project, and I can
rely only on the software solution
and this version of the program.
Thanks for the help.
With respect Osta.
With respect Osta.
