Problem with the PIC16F648 ADC
Osta
Been thanked: 13 times
Post by Osta »
The high-case ADC "ADRESH"is not read.
Previously, everything worked and now it doesn't .
When using macros (Flowcode) everything works but the program
remains in interrupts while the ADC is running and this is 100-200 uS
lose time . You can return for the result in interrupts.
Please make an ADC interrupt macro!!!
Sincerely, Osta.
File attached
ADC.fcfx
prog
(26.18 KiB) Downloaded 323 times
Re: Problem with the PIC16F648 ADC
I thinkt he problem was your interrupt enable code. You were using bit names such as GO = 1 whereas this should have been ADCON0bits.GO = 1
I've made some changes to your program inside the interrupt enable icon, hopefully it will improve things for you.
Also I've noticed your if statement had been converted to C with customised code to add a { after the decision. This should not be required but i've left as is as it doesn't seem to be causing issues in the generated code.
ADC.fcfx
(26.24 KiB) Downloaded 377 times
Osta
Post by Osta »
Hi Benj!
It doesn't change anything...
My version of the program works
only if I read lowercase,
I attached a photo below.
Sincerely Osta
Oscil
Oscil
ADRESL
ADRESL
Osta
Post by Osta »
Hi Benj!
I apologize for making a typo.
I use the PIC16F684 controller
Osta
Post by Osta »
Hi Benj!
Your recommendation doesn't work!
As before, the senior level is not readable.
Only the lower-level ADC is read.
Above is a picture of the lowercase operation
What to do?
Hi Osta,
You have set the ADC to be Right justified which means that the majority of the ADC result will reside in the ADRESL register (ADFM = 1).
ADCON0 = 137;   // Настройка АЦПа
Maybe this should instead be (ADFM = 0).
ADCON0 = 9;   // Настройка АЦПа
Osta
Post by Osta »
Рш Benj
That's right, I need to move to the right.
otherwise, I will have to do an extra operation-shift the entire result by 6 bits
When the ADC is shifted to the right, it is 768
the first two bits must be used in upper case.
ADRESH
ADRESH
Osta
Post by Osta »
The macro does this.
And I need to start the ADC and get out of interrupts as soon as possible.
Go back for the result, change the channel and exit again. This is a cycle that takes less time
, measurements run in parallel and there is no reason to wait for the result in interrupts.
Code snippet
Code snippet
Has thanked: 481 times
Been thanked: 699 times
Maybe try taking out the code that swaps ADC channel on every sample.
Just try sampling one channel to begin with and see if that works.
Osta
Post by Osta »
Hi LeighM
The macro works fine!
I can't count the upper case
when shifting to the right .
I just wondered if you were getting low value readings due to too short A/D acquisition time
Osta
Post by Osta »
Thanks, I'll check it out.
Osta
Post by Osta »
Does not work...
Try a slower conversion clock in ADCON1 ?
Osta
Post by Osta »
Hi LeighM
I did all three options the result is the same.
ADCON1
ADCON1
Osta
Post by Osta »
This is the same solution implemented in Flowcode 6
and it works.
I did the same in Flowcode 7.
FC6
FC6
Does your Flowcode 7 program work?
If so, could you post it?
Osta
Post by Osta »
Hi LeighM
I still have the old FC6 file and the new FC8 file
in FC7 it is lost but I installed FC7 yesterday and tried IT
it doesn't work either.
OK,
I've just noticed that ADRESH and ADRESL are in different memory banks, I wonder if this is a silicon/compiler issue :?
Osta
Post by Osta »
That may be so.
Well, if you can take that into account.
I can't change the controller
this is an old project, and I can
rely only on the software solution
and this version of the program.
Thanks for the help.
With respect Osta.
