Page 1 of 3
v5 Beta FAT16 component SDHC
Posted: Wed Jul 18, 2012 12:18 am
Hello Nicolas,
I haven't had time to test this on hardware yet but it compiles now so hopefully it should work. I need to buy in some SDHC cards to do the testing so may take a few days. In the meantime if you want to give it a go then backup the FC5_PIC_FAT16.c file in the "Flowcode xxx\v5\Components" folder and then copy in the attached file before starting Flowcode.
FC5_PIC_FAT16.c
(53.89 KiB) Downloaded 485 times
Let me know how you get on.
Re: SD Card not response
Posted: Wed Jul 18, 2012 12:42 am
by Nico595
Thank you very much Ben :D ,
I test this component today with my SDHC Card.
:wink:
Posted: Wed Jul 18, 2012 10:14 am
by JohnCrow
Hi Benj
Does this mean the new component will work with cards bigger than 2GB ?
Also will It work formatted FAT16 or does it need to be FAT32.
I'll give it a try tonight if I get chance with an 8GB card.
Posted: Wed Jul 18, 2012 10:20 am
by Nico595
I ve renamed FC5_PIC_FAT16.c in FC5_ARM_FAT16.c and replaced in Components Folder.
Unfortunately, component not working with all SDCard.
- With SDCard no SDHC < 2GO, After Init FAT macro I have Retval = Dec 237 (0xED hex code error -> SECTBYTES ERROR)
(Ok with old FAT component version)
- With SDCard SDHC 4GO 15MB/s (Class 4), After Init FAT macro I have Retval = Dec 254 (0xFE hex code error -> NORESP ERROR)
I ve tried in FAT32 select and AUTO select but with the even problem.
Thank for your reply,
Nicolas.
Posted: Wed Jul 18, 2012 11:03 am
Hi Nicolas & John,
Ok thanks for testing and providing the results so quickly. A bit disappointed it didn't work but not giving up just yet. I will have another dig in tonight and see if I can get any further.
I was using the Microchip SD stack as a template as this works nicely on a range of cards however it is really overcomplicated and bloated and it's not until you start to try and port it that you realise just how bad it is. Code replicated in multiple places, definitions that are bypassed or not used in the code and lots of weird compiler workarounds that would likely just cause issues with BoostC and GCC. Last night I found an AVR GCC source which is really simple and fits in with the current code base. It is said to work but obviously I have done something wrong if this is not currently working with your hardware.
The sector bytes error is interesting and may help me to debug the issue.
Yes eventually I hope to be able to support larger cards and I also want to make the SPI transactions post init much faster. One use for this may be with the DSP type functionality we are doing to provide high quality streaming audio etc.
I think FAT16 only supports cards <= 2GB so FAT32 may have to be used on larger cards, not 100% on this one. Do you get FAT as an option when you format a card larger then 2GB?
Posted: Wed Jul 18, 2012 11:21 am
by Nico595
Ok Ben,
For information:
My Small SDCard is Transcend 2GO formated in FAT32, OK with old FAT component version (but with speed writting problem when data on card is > 100 MO).
My SDHC Card is SanDisk 4GO 15MB/s Class 4 formated in FAT32 -> NORESP ERR
Good Job for tonight, I hope it will work :)
Nicolas.
Posted: Wed Jul 18, 2012 7:12 pm
Just noticed that all the SDHC cards seem to say FAT32 which I guess is understandable as a FAT16 file system would need huge cluster sizes and therefore would have large levels of redundant sectors if you had lots of small files on the card.
The quest for SDHC continues....
Posted: Wed Jul 18, 2012 7:16 pm
The SECTBYTES ERROR is related to whether the start of the partition is found. I have not edited this code so I wonder why this is failing to work correctly?
Hm, the plot thickens.
Posted: Wed Jul 18, 2012 7:53 pm
Right I have found a couple of bugs that meant that the sector read and write functions were not working correctly which probably explains the SECTBYTE error. I think this has now been fixed and I've again checked it compiles. I'm hoping this will at the very least allow the originally working card to fire up again. I have a v5 working card here so I will give this a go tonight if I get time.
Not sure what the issue is with the SDHC as this code looked ok, definitely worth retesting to see if it gets any further. In the example code it calls the init function 20 times in a loop checking for a return value of 0 before giving up.
Re: v5 Beta FAT16 component SDHC
Posted: Thu Jul 19, 2012 12:59 am
No go here :( Still working on it. Maybe tomorrow! :?
The card init is working ok but when getting to the part where it should be reading the MBR I am just getting 0's. Hopefully should be simple to fix.
Nicolas' card is firing up correctly so it looks like the issue is just with my card, still no go on the SDHC type cards yet though.
Posted: Thu Jul 19, 2012 11:03 am
by Nico595
Hello Ben,
(mp copy)
Better but other problem:
With SDCard No SDHC 2GO FAT32, Init FAT OK
Next step -> Scan_Current_Folder OK But name of folder is no good, "TRON" becomes "puovpvpwpxq"
Result -> Open Folder Error
With SDHC SDCard Error 254 on Init FAT
My prog is a loop of Init_Fat if Retval > 0 with a small delay after Init_Fat.
(.fcm export in mp)
- I ve tested in Software mode, exactly even problem.
- I ve tested with "mx_sdhc_flag = 1" fixed in macro, but Retval = 254 with SDHC Card.
Nicolas
Posted: Thu Jul 19, 2012 8:19 pm
Cheers Nicolas,
Right I'm back on with it now so I will let you know how I get on. Hopefully I can fix the file system related errors.
As for the SDHC, still not managed to get hold of one for testing yet so I am continuing with this standard class 1 SD that did not work previously, hopefully I can get somewhere with this. Annoying thing is it works great with the Microchip stack and so can work via the SPI interface!
If my SDHC card hasn't arrived tomorrow then I will nip down to the supermarket so I have one for the weekend.
This will not beat me :D (famous last words)
Posted: Thu Jul 19, 2012 9:09 pm
by Nico595
Super Ben :D
I stay in waiting ...
I use FAT16 component of V5 ARM in FAT16 and FAT32 with small change in macro, ok with SPI hardware.
Posted: Fri Jul 20, 2012 9:22 am
Right I think I have a stable version now. At least it's working with the two standard SD cards I have, 1 which worked with the original v5 code and 1 which didn't.
Next step is getting the SDHC card working, if it's not already 8)
I have also implemented a speed increase in the component code, if the init function fails then the code will try and dial back the speed for initialisation but then push it back up for the data transfer. Seems to be working well and confirmed running faster then the original v5 code on an ECIO PIC :D
FC5_PIC_FAT16.c
(56.51 KiB) Downloaded 429 times
PIC_CAL_SPI.c
(12.49 KiB) Downloaded 407 times
AVR_CAL_SPI.c
(16.87 KiB) Downloaded 404 times
ARM_CAL_SPI.c
(11.87 KiB) Downloaded 417 times
PIC16BIT_CAL_SPI.c
(21.36 KiB) Downloaded 373 times
Let me know how you get on with the new ARM CAL file, I have tested in software mode and it appears to be working.
- Edit - Confirmed AVR also working in SW mode
Posted: Fri Jul 20, 2012 12:09 pm
by Nico595
I test with my hardware immediately :D
Posted: Fri Jul 20, 2012 1:35 pm
by Nico595
Ok Ben,
I have Retval = 237 with this Mx_Init_Card.
If I replace Mx_Init_Card by this Mx_Init_Card it's OK with 2GO SDCard and new CAL, FAT, files.
MX_UINT8 RetVal;
MX_SINT16 i;
delay_ms(50); //Wait for card to power up
//Init SPI
%a_SPI_Master_Init(); //Call initialise function
FC_CAL_Bit_High_DDR (%a_MX_SPI_FAT_CS_PORT, %a_MX_SPI_FAT_CS_TRIS, %a_MX_SPI_FAT_CS_PIN); // Chip Select pin is disabled
for(i = 0; i < 10; i++) //Start CARD in SPI mode
%a_SPI_Master_Byte(0xFF); //Send 10*8=80 clock pulses
FC_CAL_Bit_Low ( %a_MX_SPI_FAT_CS_PORT, %a_MX_SPI_FAT_CS_PIN); // Chip Select pin is enabled
delay_us(50); //Wait 50us
//Command 0 - Goto Idle State - Resets card
RetVal = MX_Send_Cmd(0,0);
FC_CAL_Bit_High ( %a_MX_SPI_FAT_CS_PORT, %a_MX_SPI_FAT_CS_PIN); // Chip Select pin is disabled
if (RetVal != 1)
return MX_ERR_NOCARD; //Card not initialising or not present
//Command 1 - Send Operating Condition - Reports the status of the card
i = 10000;
do
RetVal = MX_Send_Cmd(1,0);
FC_CAL_Bit_High ( %a_MX_SPI_FAT_CS_PORT, %a_MX_SPI_FAT_CS_PIN); //CARD-Disabled
while ((RetVal) && (i--)); //Loop while processing command 1
if (RetVal)
return MX_ERR_NORESP; //Card not responding
//Need a good way of applying this speed update!!!
//%a_SPI_Master_Uninit(); //Disable Low Speed
//%a_FAT.AsByteus_mode = 1; //SPI Bus Mode //Check this value
//%a_SPI_Master_Init (); //Enable Hi Speed
//Hardware Mode only
AT91F_SPI_CfgCs(AT91C_BASE_SPI, 0, (12 << FCV_SPI_SPEED) | AT91C_SPI_NCPHA | AT91C_SPI_CPOL); // 8MBaud @ 48MHz MCK
return MX_ACK_OK; //Card Ready
and MX_SPI_BYTE
MX_UINT8 RetVal;
MX_SINT16 i;
//Init SPI
if (RetVal != 1)
i = 10000;
do
if (RetVal)
Posted: Fri Jul 20, 2012 2:14 pm
by Nico595
I've tried with FC5_PIC_FAT16.c version2 and new CAL file:
The better result, Without change code in component Macro Init Card is OK, but with this problem of bad folder name ...
Benj wrote:Right I have found a couple of bugs that meant that the sector read and write functions were not working correctly which probably explains the SECTBYTE error. I think this has now been fixed and I've again checked it compiles. I'm hoping this will at the very least allow the originally working card to fire up again. I have a v5 working card here so I will give this a go tonight if I get time.Not sure what the issue is with the SDHC as this code looked ok, definitely worth retesting to see if it gets any further. In the example code it calls the init function 20 times in a loop checking for a return value of 0 before giving up.
FC5_PIC_FAT16.c
(56.67 KiB) Downloaded 9 times
Posted: Fri Jul 20, 2012 6:48 pm
Right I'm posting from my mobile due to lack on met at home. Just bought two sdhc cards and they are both working correctly with the current posted code :-) I will try and increase the reliability but looking good at this end.
Posted: Fri Jul 20, 2012 7:01 pm
Using the current code I have 6 working cards 2 of which are sdhc 1 2GB and 1 4GB. The only card I have which isn't working is a mmc type card. May have got the prescaler values wrong for the arm so I will repeat the tests on this :-)
Posted: Fri Jul 20, 2012 7:58 pm
by Nico595
Very good news :D
Thank Ben for your working,
My hardware is like this dev card:
https://www.olimex.com/dev/pdf/SAM7S-P64.pdf
I use SPI hardware.
For test, I can take Olimex dev card.
With Flowcode, in macro component, I have Mx_macro duplicate, may be problem with new component file .c
I search this WE why my SDCard answer 237, and SDHC 254 ...
Good luck Ben.
Posted: Fri Jul 20, 2012 11:32 pm
by Nico595
I've tested with new component FAT16(1) and replaced Init_Fat macro in .fcm prog but even problem, retval = 237
Posted: Sat Jul 21, 2012 12:07 am
by Nico595
Ok :D ,
I've imagined a problem with MBR reading in init FAT, I've placed your lower speed SPI mode in Init_FAT macro and SDCard 2GO is OK with your latest FAT component code in SPI hardware.
delay_ms(50);
retval = MX_Get_Buffer(0); //Read Master Boot Record if available
//if (retval)
// %a_SPI_Set_Prescaler(4); //Try again
//retval = MX_Get_Buffer(0); //Read Master Boot Record if available
if (retval)
return MX_ERR_SECTBYTES;
delay_ms(50);
if (retval)
%a_SPI_Set_Prescaler(4); //Try again at a lower speed
if (retval)
Finally I test Prescaler value for Init and Read MBR for best SPI speed value:
retval = MX_Init_Card(); //Startup Card
if (retval)
%a_SPI_Set_Prescaler(1); //Try again
retval = MX_Init_Card(); //Read Master Boot Record if available
if (retval)
%a_SPI_Set_Prescaler(2); //Try again at a lower speed
if (retval)
if (retval)
%a_SPI_Set_Prescaler(64); //Try again at a lower speed
if (retval)
return(retval); //Startup error or no card
delay_ms(50);
if (retval)
if (retval)
if (retval)
if (retval)
if (retval)
and I've replaced Prescaler number in Mx_Init_Card
Finally after Init, Prescaler value high for best SPI speed value:
Can you tell me if it's ok ?
SPI_Set_Prescaler() is very a good idea :D
For SDHC I have 254 return.
EDIT:
After more test with 2GO SDCard, reading OK, problem with writting -> Macro Create_File, no file created on SDCard or file without name.
Posted: Sat Jul 21, 2012 9:23 pm
by Nico595
With SDHC Card (test with two SDHC Card) I have NORESP ERROR.
Problem with Mx_Init_Card ACMD command ...
In Defines of FAT Component I add code error:
//Common Defines
#define MX_ERR_NOCARD 0xFF
#define MX_ERR_NORESP 0xFE
#define MX_ERR_SDHCNORESP 0x33
In Mx_Init_Card
do
RetVal = MX_Send_Cmd(APP_CMD, 0x00000000); //CMD55, must be sent before sending any ACMD command
RetVal = MX_Send_Cmd(SD_SEND_OP_COND, 0x40000000); //ACMD41
i++;
if(i>0xfe)
return MX_ERR_SDHCNORESP; //time out, card initialization failed
I have error code 51 Dec -> 0x33 -> MX_ERR_SDHCNORESP -> time out, card initialization failed
After this Cmd I've created FCV for return value of RetVal
RetVal = 1 Dec for %a_SPI_Set_Prescaler(); >= 1, But RetVal return must be 0 Dec (0x00)
EDIT 22.07.2012:
OUFFFFFF, in French :D SDHC Init OK,
My power of SDCard is a PA7, no good with SDHC :oops: , after powered SDCard with 3.3v supply, SDHC Card Init OK :D :D :D
Perfect, Thank you very much Ben :D
Always problem with the Create_File macro, file is created but without name, result, bug SDCard reading.
Posted: Mon Jul 23, 2012 9:26 am
Hi Nico,
Sorry I dug out all my ARM hardware on the weekend and then realised I didn't have v5 for ARM installed at home and as my net was down (and still is!) I couldn't download a copy. I will install tonight and specifically test the create file and write functions. Thanks for helping with the testing.
Posted: Mon Jul 23, 2012 1:26 pm
by Nico595
No excuse, Weekend is for relaxation and no working :wink:
My card was powered with PA7 for reset, I have a problem, when I've readed card, I can't doing a new init_Fat, Card is no found. I must reset ARM for restart the reading card. I search later ...
I'm very happy FAT16 is OK with SDHC Card. I will test with others Card, faster.
For Create_File macro I think file is created without name but you must tested with your prog and hardware.
Good job Ben, Thanks :D
PS: If you want, you can delete my no necessary old post :mrgreen:
