Flowcode 4 and compiler location
john hauton
Been thanked: 2 times
Post by john hauton »
Hi, I have had this problem with flowcode4 ever since it came out. After an install it would work perfectly.
Then for some reason the compiler/linker location gets changed, and it throws up the following:
Error: Failed to open:libc.pic16.lib or C:\Program Files\SourceBoost\lib/libc.pic16.lib
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
Could someone please tell me why the location of the above file pointer changes, even after selecting default and
what the correct line should look like
john
Re: Flowcode 4 and compiler location
Hi John,
Have you looked here:
http://www.matrixmultimedia.com/support ... f=22&t=683
Martin.
ardu
Has thanked: 20 times
Post by ardu »
The posted solution works for a session. But after exiting flowcode 4 one day and re-opening flowcode for use the next day, the linker options go back to the following (even if flowcode is set for a pic 16):
-ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
Then I have to re-apply the solution given in the above post. Even previously coded and compiled programs revert to the above linker options so that I have to change the linker options to the options specified in the above post before the assembly will compile.
How can I change the compiler options so that the compiler options stay changed and do not revert back to the values they were before I changed them after completely exiting flowcode 4.
Hi ardu,
attached are some regisry files.
you can edit the correct version for your operating system to suit your needs then run it.
Flowcode Default with PPP win 32 & 64Bit.zip
(1.24 KiB) Downloaded 420 times
ardu
Post by ardu »
I executed your code and set the registry files. Flowcode continues to have the same problem I had before I executed your code. The values are right for awhile but then the values for linker / assembler parameters reverts back to the following:
A difference from my original post, which I think I just did not notice before, is that I do not have to exit flowcode for it to revert back to the above values. I can just leave flowcode open a day or two without closing it and the values still revert back to the above linker / assembler parameters. Flowcode seems to be reading some file periodically that has the above linker / assembler parameters. I find out about it because flowcode no longer links without errors. How do I fix this problem?
Hmm this sounds strange.
Just to confirm your not using any clean up software, antivirus, antimalware or registry maintenance applications which may be overriding the parameters you have set.
Also could it be there are multiple users that use the same machine but with different settings?
Maybe installing Sourceboost IDE or something similar?
Sure this is not a Flowcode issue as Flowcode only writes to the registry when you update the properties in the compiler options window.
Might be worth going in there and saving the working settings so you can recall them straight away if you ever need to (sorry noticed your using v4 and v4 cannot do this).
Kenrix2
Flowcode v5 User
Has thanked: 72 times
Been thanked: 177 times
Post by Kenrix2 »
I am not sure but, apparently someone else had this same problem. Have a look at:
http://www.matrixmultimedia.com/mmforum ... ode#p31236
Perhaps you could send john a pm to see if he remembers the solution.
ardu
Post by ardu »
I am the only user. I do have a Norton Utilities registry maintenance program that runs but it has often run 3 - 4 times before the flowcode problem occurs. The flowcode settings last a couple of days before reverting back to the old values. I have the correct settings set in notepad which I use to copy/paste the correct flowcode settings back into flowcode. I can just continue to do that but was hoping there was a permanent solution.
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Dont know if you've tried this but when you re add the correct settings, make sure the top drop down box says default, then click on the save button next to the drop down box, what may be happening is you have a default and current set up and it switches from one to the other, if so do the same for the current, it may or may not sort it but its worth a try
ardu
Post by ardu »
I cannot find what you discussed. I am using version 4.5. Are you using version 5?
dazz
Post by dazz »
Ah
yes sorry the instructions i gave are for v5 sorry
Dazz
Kenrix2
Flowcode v5 User
Post by Kenrix2 »
Please try these settings in Compiler Options if you have a 64 bit machine. If they don't work maybe you could post your settings after hitting the "Restore Defaults" button in the lower left of that window.
Compiler:
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe
Parameters:
-v -t PIC%p "%f.c"
Linker/Assembler:
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe
Parameters:
-ld "C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
I used the following post as a guide but added (x86) in Linker/Assembler Parameters, The original poster solved the problem but didn't really explain the solution so this this is the best I could come up with.
http://ww.w.matrixmultimedia.com/mmforu ... f=2&t=7822
john hauton
Hi Martin, sorry about the delay..
This problem only started when I installed the demo version of flowcode dsp.
It seemed to change the linker locations, and point to the dsp linker.
I've found a way to cure it, but somewhat drastic!
Un-install ALL flowcode software.
Re-boot
Re-install everything.
There must be an easier way, as I have three flowcodes (pic avr arm) professional
so its a few hours work.
regards john
ardu
Post by ardu »
OK. The above post may indicate why I have had problems.
I had originally installed the free version of flowcode 4.5 available on a companion site to a book I had bought. After I became familiar with it I decided to install the paid for version that I got with a course I had paid for, "Programming Embedded PIC Microcontrollers". I uninstalled the free flowcode 4.5 and installed the paid for version of flowcode 4.5. Since I could not get the registration to work right, Matrix staff manually registered for me. I guess things got messed up because I originally installed the free version and then uninstalled it instead of upgrading.
Since I uninstalled the free version of flowcode 4.5 before I installed the paid for version of flowcode 4.5, I do not understand what I should do different if I tried uninstalling my paid for version of flowcode 4.5 to try to reinstall it so that the settings will stay correct.
