Compiler keeps going and going and going - Resolved
Forum for Flowcode v6 beta users
Locked
acestu
Has thanked: 783 times
Been thanked: 223 times
Post by acestu »
Has anybody come across this, when I try to compile chart to Hex or compile to chip, the compiler starts and the dots just keep going and going across the screen until you get bored and have to press the cancel button.....
EDIT: Getting this error now
(7 KiB) Downloaded 9237 times
thanks
Acestu
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Compiler keeps going and going and going
Post by JonnyW »
Hi. Have you successfully compiled before and it has suddenly stopped working, or has this always happened?
Does it do this with a simple (i.e. empty) project, or any chip, or is it a specific program or chip?
Does this happen consistently, or is it only occasionally?
Cheers for any answers,
Jonny
acestu
Post by acestu »
Hi Jonny,
Over the past few days this has happened occasionally whilst trying to program chip, I have then tried again and it has worked but this time I can not get it to work, even just rebooted pc twice and tried again but no luck, I am going to post the chart so somebody else can try and compile to Hex or chip, you will have to install Benj's Visi Component first though, the chart is not complex I had only just started it...
multiDemo.fcfx
(5.97 KiB) Downloaded 657 times
cheers
Acestu
acestu
Post by acestu »
Hi Jonny,
I have just loaded my last chart that did work and now that will not compile, it is doing the exact same thing, I will try some other actions and update shortly..
thanks
Acestu
acestu
Post by acestu »
Hi Jonny,
I have just made a simple chart with a switch and a lamp and it will not compile it seems nothing will now compile, one thing I noticed tonight when I started using Flowcode was when it was starting up a box came up saying that I only had 5 days left on my temporary key, could this be connected ?
(7.95 KiB) Downloaded 9227 times
Acestu
acestu wrote:when it was starting up a box came up saying that I only had 5 days left on my temporary key, could this be connected ?
That's exactly what I said to Jonny a few minutes ago.
Only just read this.
How strange!
JonnyW
Post by JonnyW »
Hi. It will be annoying if that is the issue - I don't see why the protection should be playing about with launching apps like that, but never know. You are both right - it is a coincidence...
I'll take a look at a protected version of Flowcode tomorrow. Can't be releasing patches that don;t compile. Out of interest, what about the other platforms (PIC16, AVR, ARM)? Is it just BoostC?
Jonny
acestu
Post by acestu »
Hi Jonny, Martin,
I will have a mess and update in a moment or 2.
cheers
Acestu
acestu
Post by acestu »
I have just made a chart in ARM and it compiled lightning fast, I must say all the sucsesful pic compiling that I have done in FC6 has taken a lot longer than in FC5, I don't know if that is normal, but it still seems boostc is broken now because no pic projects will compile.... :(
cheers
Acestu
P.S. I will try other platforms now
acestu
Post by acestu »
I just tried a simple AVR chart but when I tried to save it before compiling I got this error:
(27.41 KiB) Downloaded 9220 times
cheers
Acestu
acestu
Post by acestu »
I have just tried another Pic chart and no luck it is still broken...... let's see what you can find out tomorrow Jonny....
cheers
Acestu
I also tried a different much simpler Flowchart that I know worked a couple of days ago.
Now it does not compile. You can tell from the shrinking bar at the bottom that compiler keeps compiling.
(69.3 KiB) Downloaded 9213 times
PIC16, ARM, AVR Does not suffer from the continuous compiling issue.
acestu
Post by acestu »
Pic16 compiles fine and fast
cheers
Acestu
Update:
I set my laptop date back to the 26th of Aug.
Ran Flowcode and the 5 day message did not appear.
Created a new PIC flowchart, and it compiled as normal
Closed Flowcode, set date to today.
Ran Flowcode, 5 day message appeared.
Flowchart no longer compiles.
So now the same on my main 64bit win as the 32bit win laptop.
Stronger evidence that 5 day message is causing a compiler issue.
acestu
Post by acestu »
Hi Martin,
I had a sneaky suspicion it might be something to do with the protection............. :shock:
cheers
Acestu
acestu
Post by acestu »
Anybody reading this thread it seems like the 5 day warning at Flowcode startup is causing problems when compiling pic devices, Matrix have said that they are working to fix this ASAP...
cheers
Acestu
This should be fixed in the new patchset which should be available in the next hour or so. Just putting it all together now.
acestu
Post by acestu »
Hi Benj,
Thank you for sorting this problem so fast,
I have installed the patch set then rebooted although not mandatory, now all is well and working as far as I can see... :D
cheers
Acestu
Locked
