DS18B20 & Memory (ROM) usage
Bachman
Has thanked: 9 times
Been thanked: 53 times
Post by Bachman »
Hello!
The OneWire component is not working with DS18B20. I've created the same flowchart in Flowcode v5, and there everithing is looks fine. One other interesting thing: The v6 version needs double size program memory than the v5, while needs less data memory (not big difference).
I've tested the communication, the results is attached. With the version v6, the communication lenght is around 20 ms only.
DS18B20_test.fcfx
(5.39 KiB) Downloaded 337 times
Bachman
Re: DS18B20 & Memory (ROM) usage
Post by Bachman »
Other memory usage test. Simple, GPS* based clock with 4 x 7seg display (direct drive).
*ublox NEO 6M module
GPS_Clock_v6.fcfx
(118.08 KiB) Downloaded 346 times
GPS_Clock_v5.fcf
(127.25 KiB) Downloaded 351 times
acestu
Has thanked: 783 times
Been thanked: 223 times
Post by acestu »
Hi Bachman,
Thanks for displaying your findings, I think this is a job for Matrix, it maybe already sorted in the next big update......
Stuart
