save the project
save the project
save the project Ctrl + S,
sometimes disappearing panel
or both.
Regards Slava.
or both.
Regards Slava.
- Sav.jpg (35.12 KiB) Viewed 32439 times
Re: save the project
Hi Steve!
Yes, closing the window helps!
The problem is not easy, I'm sure you can do it !!!
Steve tell me Russian interface will come back?
Regards Slava.
Regards Slava.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
We were aware that most users were using English and so we decided to remove the other languages temporarily from this initial release. We can add the languages back if you like.
Russian course very convenient.
I understand that the program easier to correct in English
I wish you good luck and patience!
Regards Slava.
Regards Slava.
johnsondav
- Has thanked: 86 times
- Been thanked: 186 times
Hi Slava
I too have the problem you describe
FC7 Build 7.0.0.4
Windows 10 Pro - Ver: 1511
OS Build - 10586.494
Think the problem is FC7 not our computers. We only use what you made available.
FC7 Build 7.0.0.4
johnsondav
Hi Steve
I think I have a solution for the icon's going missing upon saving. I have solved the problem on my PC with the following:
- Open Global options
- Select the menu 'Application'
- Change OpenGL from 'Hardware', to 'Software' as shown below:
Works for me. Hope it helps others.
Dave
Dave
johnsondav
Hi Osta and EtsDriver
I don't believe it. Everything was working fine. So, I started a new project to test my set up as I had finished the previous project and could not replicate your problem. However, with a new project started, your right, the left-hand side menu keeps disappearing upon doing a save. This is very strange indeed and I am beginning to thing it is an OpenGL driver problem. This is my hardware details:
I have tried to make further changes to my graphic drivers setting without success. Would be interested to know if you are using similar to mine.
Dave
Dave
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
For others curiosity, im having same things happening as Osta/johnsondav and keep sometimes losing all the toolbar icons from the GUI, and i use Nvidia GTX970. What GPU does Steve have?
johnsondav
Hi EtsDriver
Thanks for sharing your Graphics hardware details. It has help to suggest my concern that the problem may be to do with the drivers. We'll only know when other give details of their hardware/drivers that does not produce this problem.
I have a gaming laptop with a Nvidia 670M however it has a dual mode with an on-board Intel GPU and the Nvidia card is only fired up when needed to save power so not 100% sure which is being used for Flowcode.
I'll ask around the office and see if we have other Nvidia based machines we can use for testing.
It's a laptop that Steve uses so I would guess it's an on-board Intel GPU.What GPU does Steve have?
- petesmart
- Has thanked: 187 times
- Been thanked: 140 times
I'm running a nvidia quadra4k and fc7... It's running hires +2500 pixels...I will have to check the exact resolution and come back to you.....What tests would you like me to run for you?...
Best
Pete
Best
Pete
sorry about that Chief!
EtsDriver
Would be intrested to hear some other facts, like what OS, RAM amount, what CPU if you can providepetesmart wrote:Hi,
If you can and want to test out, put your system screen close to 1920x1080 resolution (if your GPU can handle it and you can still see the texts well, dont know about what systems and screens you are using really
I go now test out what happens if i use the dark theme... :O
EDIT:
I updated my GPU to same drivers as johnsondav. (Nvidia GeForce GameReady Driver 368.81)
After opening old things in dark theme and pressing save icon couple times, seems that the icons go out of their place on dark theme, if looking by the undo and redo buttons: When some items are pointed, they go back to their original positios: Video can be found behind this link:
https://youtu.be/zWr1V4b8q0Y
The things on video happen in both modes, the HW and SW OpenGL. While pressing save icon rapidly, seems that the icons get messed up much easier.. Or im just imaging things.
EDIT2:
I tried changing out my GPU to older GTX750TI and the problem shown on video is still happening.
johnsondav
Hi EtsDriver
Thanks for taking up so much of your time on this GUI problem. I have tried all the options as I can think of related to graphic adaptor settings (BIOS settings, type of cable to monitor, screen resolution, various Nvidia control panel settings etc..), nothing changes the problem. I have also been looking for any event logs that might show up any Windows 10 problems during boot up, none found. I did find this though - a log in the Flowcode 7 directory:
This redrawing issue with tabs problem has been present at some time. Could still be a problem with Flowcode 7! Just a though, before we get too sure it is our computer system.Flowcode & - logs
Changes in this version: alpha_2_160713
flickering issue in components bar when resizing
flickering issue in tabs when resizing
Fixed toolbar so that the help and code profiling buttons now show tooltips
Resizing components when grid is enabled and aspect ratio locked
Resizing components toolbar
Loading Workspace window layout
Redrawing issues in tabs
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Thanks for all your investigations on this.
I've been running into similar issues on my PC, which has NVIDIA adapter.
But running the latest (pre-release) executables from our dev team I am no longer seeing the issue.
So no doubt you will benefit from the next update release
