scale issue
Steve001
Has thanked: 460 times
Been thanked: 523 times
scale issue
Post by Steve001 »
Hi Not sure if this is me or not
on 2d dash placed
generic lcd display then set to 4 x 16
switch array on port B
Analogue slider
The scale seams to be off or can you alter the zoom on each component ?
Under normal viewing the display shows lines 0,3 very small and lines 1,2 quite large and the test is quite burley.
Also in the lcd properties box there is a menu for lcd display R/W pin if hard wired to ground set to "false" if hard wired to ground the menu options shows"yes" , "no"
if I zoom so I can see the 4 lines on my display the analogue input slider is off the top of the screen
Screen res is set to 1680 x 1050
Has thanked: 481 times
Been thanked: 699 times
Re: scale issue
Hi Steve,
I guess we will need to look at default sizes.
To alter size and position I personally use the position and size properties for the component ...
Hope that helps
Steve001
Re: scale issue
Post by Steve001 »
cheers Leigh will have a go with that later
