Arduino Uno R3 and Combo Board, unable to Compile
Thoth
Post by Thoth »
Hi there,
I have got a problem with FlowCode v7.1.1.0 in combination with the Arduino Uno R3 (EB093) and the Combo Board (EB083).
Every time I add the Combo board to the Project, I can't Upload it anymore and the Compiler spits out the following Error.
Target folder: C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1
Source name:   C:\Users\Lord-Thoth\Dropbox\LN\Arduino Mikrocontroller\Flowcode3.fcfx
Title:
Description:
Device:        AVR.ATMEGA.ATMEGA328P
Generated by:  Flowcode v7.1.1.0
Date:          Sunday, January 29, 2017 11:45:35
Users:         1
Registered to:
Licence key:   *****
   NICHT FÜR KOMMERZiELLE ANWENDUNGEN
http://www.flowcode.co.uk
Start des Compilers...
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat  atmega328p "C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.elf" "C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c" "C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.lst"
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -funsigned-char -o "C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.elf" "C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c" -lm
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1518:21: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_03d92_led_base__TurnOn':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1518: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1518: error: (Each undeclared identifier is reported only once
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1518: error: for each function it appears in.)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1528:25: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_03d92_led_base__TurnOff':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1528: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1553:21: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_03d91_led_base__TurnOn':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1553: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1563:25: error: macro "FCP_SET" requires 5 arguments, but only 2 given
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_03d91_led_base__TurnOff':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:1563: error: 'FCP_SET' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05264_switch_base__ReadState':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4803: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4803: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05264_switch_base__WaitUntilHigh':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4876: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4876: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05264_switch_base__WaitUntilLow':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4947: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:4947: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05263_switch_base__ReadState':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5032: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5032: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05263_switch_base__WaitUntilHigh':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5105: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5105: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c: In function 'FCD_05263_switch_base__WaitUntilLow':
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5176: error: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\LORD-T~1\Dropbox\LN\ARDUIN~1\Flowcode3.c:5176: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat Hat den Fehlercode 1 gemeldet
BEENDET
Can you help me with this Error?
Thanks!
Flowcode3.c
(161.81 KiB) Downloaded 287 times
Flowcode3.fcfx
(5.02 KiB) Downloaded 266 times
Re: Arduino Uno R3 and Combo Board, unable to Compile
The problem is the two unconnected pins on the combo board component A6 and A7. For now I would suggest connecting these to C4 and C5 on the component properties to allow the program to compile.
I'm seeing if I can get rid of this issue so that unconnected pins with the combo board component do not cause a compile error.
These two updated components should solve the problem for you. Both files need copying to your "Flowcode 7/components" folder before restarting Flowcode.
switch.fcpx
(4.69 KiB) Downloaded 305 times
led_base.fcpx
(2.98 KiB) Downloaded 302 times
Let me know how you get on.
Thoth
Post by Thoth »
Btw, your solution works really great. Thanks for that!
