Lead-acid battery activator 0-30V
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
By means of a PIC16F1847 microchip and Flowcode 7 a pulse of about 100A during 100usec prevents sulphatation of the Lead-acid batteries. The repetition rate is 30 seconds.
A second use of this setup is to measure the quality of each battery in the range from 0-30Volt. The idea is simple, measure the loss on terminal voltage and the current during the current pulse and the internal resistance Ri can be calculated by:
Ri = (V0-Vt)/I, with Vo the terminal voltage without shunt and Vt with shunt (Rshunt=50 mOhm). Knowing the shunt resistance and measure the voltage difference over this shunt will give the current I:
I= (Vhigh-Vlow)/Rshunt and thus Ri= Rshunt x (V0-Vt)/(Vhigh-Vlow)
This has been published these days in Elektor (March/April number 2017, see below [1] and [2].
During the pulse, 3 voltages should be measured, Vt, Vhigh and Vlow. The Flowcode 7 standard macros for these 3 ADC's were to long. A remarkable reducing of time was possible to write the 3 ADC measurements in C. Please find a short, special Flowcode article attached here. The Flowcode attached is only the part of the ADC procedures.
LCD showing Vo, Vt, I, Ri and countdown counter
With kind regards
Jan Lichtenbelt.
Lead-Acid activator ADC part.fcfx
(17.72 KiB) Downloaded 416 times
1. Login or sell:
https://www.elektormagazine.com/magazine/elektor-201703
https://www.elektormagazine.com/magazin ... 703/40237/
2. Public available short version:
https://www.elektormagazine.nl/labs/act ... ors-160064
Last edited by Jan Lichtenbelt on Fri Feb 17, 2017 12:24 pm, edited 3 times in total.
Steve001
Has thanked: 460 times
Been thanked: 523 times
Re: Lead-acid battery activator 0-30V
Post by Steve001 »
interesting project jan
