I'm triing to make nrf24l01 transciever and reciever. Interesting this is that everything worked, but it stoped, and I cant make it to work again.
Can somebody take a look at the programs.
Predajnik is TX
Prijemnik is RX
THX
nrf24L01
nrf24L01
- NRF24L01_Predajnik.fcfx
- (10.89 KiB) Downloaded 272 times
- NRF24L01 Prijemnik.fcfx
- (10.88 KiB) Downloaded 282 times
electron67
- Has thanked: 106 times
- Been thanked: 48 times
Re: nrf24L01
I also did the same thing, I did my own TX and RX and excellent work with the example published in Wiki, I work as 3 continuous transmissions, after that I could no longer run the nRF24L01. . .
Enrique
Enrique
Re: nrf24L01
I wrote the component based on an Arduino library to the point where it was working nicely. I haven't seen the suddenly no longer working problem and it was certainly up and running for a fair bit longer than 15 minutes.
Could it be something to do with voltages? Is the module powered at 3V3? if so then what voltage is your microcontroller I/O running at? If it's running at 5V then it could be that which is damaging the module over time.
A simple way to shift your 5V outputs to 3V3 is to use potential dividers on each output pin (CE, CSN, MOSI, CLK). MISO is an input pin so potential divider is not needed for this one.
https://a.pololu-files.com/picture/0J14 ... e8ec7aa643
