Compilation error?
Osta
Been thanked: 13 times
Compilation error?
Post by Osta »
The display has connected 7 segments.
At emulation reports about a mistake
refuses to compile
refuses to compile
warns
warns
settings
settings
Osta
Re: Compilation error?
Post by Osta »
Osta wrote:The display has connected 7 segments.
BG.fcfx
project
(9.99 KiB) Downloaded 207 times
As you have common pins 2 & 3 unconnected, flowchart will not compile.
You need to connect common pins 2 and 3.
If you only have x2 7seg displays instead of x4, then you need to use 7Segment(Single) instead of 7Segment(Quad).
If you can't find it then select search and enter 7seg
Osta
Post by Osta »
Hi Martin!!!
Thanks for explanation.
I have so thought too... To make such decision
i was forced by an opportunity in
settings the mode - "aren't included".
I have made just as you have told and everything works!!!
Control "isn't included" to me it is unclear... :(
Osta
How does it work?
How does it work?
BG.fcfx
Here is how I have made it
(11.51 KiB) Downloaded 176 times
