Screen/cursor control in simulator
keithh534
Has thanked: 15 times
Been thanked: 12 times
Post by keithh534 »
I've tried using the "RawSend" and "Command" methods of the generic 4x20 LCD component to no avail. Do they not work in the simulation or am I doing something wrong?
I've tried the following:
The results are all the same: No effect on LCD display (Can't turn display off, set blinking cursor, or turn cursor on/off)
Re: Screen/cursor control in simulator
I'm afraid the simulation doesn't currently support these functions. We can look at adding them if they would be of benefit.
keithh534
Post by keithh534 »
Without it being implemented in the simulation, there's no way to confirm if the methods will actually work when compiled to the chip, so it seems to me it should be implemented in the software or the methods removed (preferably enabled in the simulation).
Thank you for your help.
