ComPorts not visable in FC7.3 [Solved]
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team.
I am unable to select the Comport in FC7 ,I tried the UART Component and the Hi Injector none allows me to select my ComPort
which is available and working correctly.
You will see if I use my terminal program I can select the ComPort however in FC there is no Port available to select.
Am I missing something here ,I would have expected when I click on the port in Properties the available ports will show up :oops:
I have restarted my computer a few times as I thought it will FC will refresh the ports
Any suggestions advise :D
gdt
Has thanked: 25 times
Been thanked: 36 times
Re: ComPorts not visable in FC7.3
Post by gdt »
Hello Qmesar,
I see COM5 in my laptop when I connect my USB->RS232 adapter. Check in Windows Device Manager if the port show up correctly. If it's assigned to other application you can try to change to a spare one.
Just my guess!
Giuseppe
(20.82 KiB) Downloaded 2983 times
QMESAR
Post by QMESAR »
Thank you for your reply ,I have done that in "device manager" the port is available for selection it is only in FC that it is not available :D
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
QMESAR wrote:Hi
Hello!
I think this is a general RS232-injector bug.
Arduino nano328 does not work.
I can not select the COM port.
Clean installation, Win10 proff 64 bit, running in Administrator mode.
QMESAR
Post by QMESAR »
STibor wrote: I think this is a general RS232-injector bug.
Thank you for your reply :D
This could be linked to a Microsoft .net runtime issue. I was testing 7.2 with a clean windows 10 build and found that no COM ports were available. We then re-built our DLL libraries using the same runtime that Flowcode uses (previously 2008, now 2013 I believe) and this fixed the Windows 10 problem for us. We included these new DLLs in v7.3.
Might be worth trying to install the x86 versions of the .net 2008 and .net 2013 runtime to see if that helps things at all.
When moving to 7.3 did you do a fresh install or a patch? I wonder if the patch isn't replacing the DLL files correctly?
Here is the current 7.3 COM port DLL, it needs extracting from the zip and lives in the "Flowcode 7/components/dll" folder.
SerialDLL.zip
(27.08 KiB) Downloaded 319 times
Let us know how you get on.
QMESAR
Post by QMESAR »
Thank you for the file I will try it .
:D
QMESAR
Post by QMESAR »
I apologize I only realized now that I did not mention the OS.
So yes I installed the full installation not the patch ,I have 2 machines 1 is Running WIN10 I have no issue on this machine ,the other machine is a WIN7 machine which I actually use for my LAB work and on this WIN7 32bit machine I can not acces the ComPort
Please do not worry about this, I know WIN7 is old and I should perhaps replace the LAB machine but economics in Russia does not allow for this at the moment.I can ,live with out Comport in FC on this machine if the ICD is working and now it does after the float fix in XC8 :D
Hi Peter,
Win7 should work fine but you will maybe need a redistributable to allow the COM ports to work.
Please can you try installing this on your Win7 machine. EDIT - This is the wrong link, see next post.
https://www.microsoft.com/en-gb/downloa ... x?id=40784
Sorry I've just been told it's the 2015 release you need, not the 2013 one.
This link should fix the problem with 7.3 on Windows 7 / Vista.
https://www.microsoft.com/en-us/downloa ... x?id=53587
QMESAR
Post by QMESAR »
Hi Ben.
You guys have just blown new life into my WIN7 Lab machine .it is good for another few years :D :D :D :D
Thanks a million to you and the Team
Has thanked: 1135 times
Been thanked: 299 times
Re: ComPorts not visable in FC7.3 [Solved]
Post by jgu1 »
Hi Ben!
Do I understand it correct, is it a bug in FC. 7.3 and do you recommend all to replace these file, please.
Br Jorgen
Hi Jorgen,
Not a bug as such, in 7.2 we used the 2008 .net runtime for our DLLs, this worked fine under Win7 but didn't work in Win10 without installing the 2008 .net runtime from Microsoft.
In 7.3 we upgraded the DLLs so they use the 2015 .net runtime which works fine under Win10 but not in Win7 without installing the 2015 runtime.
It basically boils down to the way Microsoft manage their runtimes.
STibor
Post by STibor »
Hello!
Win10 64bit does not work, com detection.
Installed:
runtime 2008,
I installed the runtime 2015.
Does not work.
The old Flowcode6 dll file is copied, the port recognition in v7 works.
