Thanks Ben,
I can confirm that flowchart compiles ok.
The other issue regarding this is how to match the hardware with software.
As I have chose 4 pins (12LEDs) I'm looking for a diagram which will match LED1 on flowchart with LED1 on a circuit diagram ect.
Can the diagrams with LEDs numbered and matching pins be added to wiki?
I'll get something like this uploaded to the wiki.
I believe the rule is that the LED connections stay as was from the last pin count say from 3 pins to 4 pins and then add the extra LEDs starting from pin0 and working your way through.
That's brilliant thanks for letting us know. Glad it works nicely, do you think the delay should be added to the component to save you having to add it yourself?
Glad I can help.
If you did add a delay, then It would be best to add a new parameter so you can specify as delay time in microseconds or milliseconds.
Reason for the choice is you may wish to dim the leds.
If not easy to do that then I believe it's best to add delay manually.
