Just found these 2 bugs in the esp8266 module
1. GetFrimwareVertion returns the string "ALT+GMR", not the actual version.
2. CheckTCPServerIP will freeze the mcu and will not return any string . ( only when connected to an SSID in AP mode works OK )
I think these bugs are due to esp8266 firmware updates I think some commands has changed .
The firmware version of my ESP is :
AT version:1.4.0.0(May 5 2017 16:10:59)
SDK version:2.1.0(116b762)
compile time:May 5 2017 16:37:48
ESP8266
Re: ESP8266
Hi Alan,
Please can you attach your program so we can see what's going on and try to replicate here.
Re: ESP8266
hi Benj
I have discontinued this part of the project because all HTML code is stored
on the microcontroller and have a lot of limitations + it's a bit slow to execute so
I am trying something else
my problem was 99.99% because of the different build version that I was using.
thanks .
thanks .
