Disable fields in Component Properties
viki2000
Has thanked: 30 times
Been thanked: 77 times
Post by viki2000 »
This is a general question about situations when we make a new component.
I have chosen as particular example the SSD1306 I2C display.
How do you set the Properties of the component, when you create the component, to be able to disable/enable fields based on what we choose in a list of a previous field?
Look at the screenshot below and please tell me how you do that:
Disable fields in Component Properties.jpg (100.57 KiB) Viewed 6992 times
Has thanked: 481 times
Been thanked: 699 times
Re: Disable fields in Component Properties
First create a property change event macro, see the EV section, click on "Property" to create a macro that runs when a property value changes ..
Then in the macro you can set individual properties as visible or not, writable or not ...
using a sim icon, and the listed functions ...
Hope that helps
Leigh
viki2000
Post by viki2000 »
Thank you Leigh!
I will try it out hopefully tomorrow and I will let you know how it goes.
viki2000
Post by viki2000 »
A little bit more help is welcome.
I started to look at the quadrature encoder possible improvements and I use the source code provided here:
http://www.flowcode.co.uk/mmforums/viewt ... =7&t=19676
Below is my trial component that does not work now.
I tried to add the event property change macro, the decision and the set visible function as you recommended, but it does not work. I think I make mistakes how I set up the things.
What I want is this: when I choose the property field Debouncing with OFF, then I want the Repeat Rate to become disabled.
Could you help on this particular example?
QuadEnc2a.fcfx
(32.61 KiB) Downloaded 292 times
The EV_Property_Change macro was the wrong type for the event.
So I've created a new one, EV_Property.
Just check that you create the macro by double clicking EV->Property,
then in the Add Event dialog click Macro->Add new
then OK & Edit macro
A correct macro is shown as attached to the event by an icon ...
Also I think that the property variable names have to be used rather than the "cosmetic" title names, but I could be wrong, I've not checked that.
Hope that helps
Leigh
QuadEnc2a.fcfx
(33.79 KiB) Downloaded 258 times
viki2000
Post by viki2000 »
I did exactly what you did, only that I named the macro Ev_Property_Change as I have seen in your first screenshots above.
Now in the last code proposed by you – it works! – I have seen that you named the macro it Ev_Property.
But it should not matter.
I checked one more time my initial code and I found the problem.
I played with “fire”.
So, in my initial code the macro was listed under incompatible macros, that’s why did not work.
And it was listed there because I changed the return to nothing and you let it Long.
I went back to my initial code with macro named Ev_Property_Change, I changed the Return to Long and it works too!
What’s happening now: when I choose the Debouncing OFF, then the Repeat Rate property disappears completely, it is not to be seen anymore.
What other property can I choose to make it visible but disabled, I guess not writable, as in my first screenshot example with SSD1306 display?
viki2000
Post by viki2000 »
A short double check confirms my guess: the SetWritable instead of SetVisible makes exactly what I wanted.
And you were right, the cosmetic name does not work, it must be used the variable name.
Thank you for your help!
