Miac dsPIC Ketpad
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Miac dsPIC Ketpad
Post by Monie Jacobsen »
Hello..
Is there anyone who can describe what I'm doing wrong with the Miac dsPIC Keypad (MI5809.
Can not see any result in the display by test ...
I'm absolutely sure I'm ignoring something.
Would you like to help make the codes work and results can be seen in the Miac dsPIC Display.
See attached codes:
Keypad Test.fcfx
(15.05 KiB) Downloaded 478 times
Best Regard
Monie
Has thanked: 481 times
Been thanked: 699 times
Re: Miac dsPIC Ketpad
Hi Monie,
You need to change your target to a MIAC dsPIC.
Build->Project Options->Choose a Target
PIC16->Misc->MIAC (dsPIC)
Leigh
Monie Jacobsen
Hi Leigh,
Thank you very much :-)
What is the difference between choosing Miac (dsPIC) or Miac (dsPIC) System ??
Best Regard
Monie
Monie Jacobsen
Hi Leigh,
Have tried via the Miac dsPIC to get the GPS device to work, but unsuccessfully!
Miac dsPIC og Miac GPS.JPG (27.58 KiB) Viewed 23060 times
But get the error message as shown below, you can see how this should be done?
Icon List.JPG (15.95 KiB) Viewed 23060 times
MIAC_dsPIC_GPS.fcfx
(45.71 KiB) Downloaded 459 times
Compile message:
Target folder: C:\Users\Bruger\Desktop\TILFOR~1
Source name:   C:\Users\Bruger\Desktop\Til Forum\MIAC_dsPIC_GPS.fcfx
Title:
Description:
Device:        PIC16.33E.MIAC (dsPIC)
Generated by:  Flowcode v7.3.0.5
Date:          Monday, June 04, 2018 12:04:26
Users:         1
Registered to: monie jacobsen
Licence key:   YUWNEC
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat  "MIAC_dsPIC_GPS" "C:\Users\Bruger\Desktop\TILFOR~1\" "33EP256MU806"
Launching compiler...
C:\Users\Bruger\Desktop\TILFOR~1>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "MIAC_dsPIC_GPS".c -o "MIAC_dsPIC_GPS".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
In file included from C:\Program Files (x86)\Flowcode 7\CAL\includes.c:41:0,
                 from MIAC_dsPIC_GPS.c:443:
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:36:26: fatal error: MIAC_CAL_API.h: No such file or directory
compilation terminated.
Error returned from [xc16-gcc.exe]
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
Best Regard
Monie
You need to choose "MIAC (dsPIC) System" when using the MIAC Expansion modules (such as GPS)
this then includes all the "system" functionality.
I'll now take a look at your latest flowchart
Hi Monie,
Yes, you need to change the target to "MIAC (dsPIC) System"
Also, the "number" variable error is due to the use of the global "number" variable in your PrintDecimal macro that is not given a value.
I think you intended to use the parameter ".PrintDecimal" not "number"
MIAC_dsPIC_GPS.fcfx
(45.73 KiB) Downloaded 464 times
Monie Jacobsen
Hi Leigh,
Thank you for your code.
I get the following error message: C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
Do you have a suggestion to resolve the error message below.
Reported error:
Target folder: C:\Users\Bruger\DOWNLO~1
Source name:   C:\Users\Bruger\Downloads\MIAC_dsPIC_GPS.fcfx
Title:
Description:
Date:          Monday, June 04, 2018 13:36:42
Users:         1
Licence key:   YUWNEC
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat  "MIAC_dsPIC_GPS" "C:\Users\Bruger\DOWNLO~1\" "33EP256MU806"
C:\Users\Bruger\DOWNLO~1>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "MIAC_dsPIC_GPS".c -o "MIAC_dsPIC_GPS".o
                 from MIAC_dsPIC_GPS.c:444:
FINISHED
Best Regard
Monie
Have you got the following directory? ...
C:\Program Files (x86)\Flowcode 7\CAL\MIAC
Is there anything in it?
MIAC_CAL_API.h in particular
Monie Jacobsen
Hi Leigh,
I have the following files in Flowcode/CAL/MIAC:
Best Regard
Monie
Hmm, MIAC_CAL_API.h is missing, attached.
MIAC_CAL_API.h
(2.89 KiB) Downloaded 430 times
Monie Jacobsen
Hi LeighM,
Thank you very much for your patients.
It looks like it's working now.
Best Regard
Monie
Monie Jacobsen
Hi LeighM,
How do I put the coordinates in miac - gps longitude and latitude, so they work?
Best Regard
Monie
Hi Monie,
If you mean for simulation, unfortunately there is not much simulation for the Expansion modules.
Monie Jacobsen
Hi Leigh,
I mean i the real world ;-)
Wish to GPS Read longitude and latitude!
Please see below on the codes!
MIAC_dsPIC_GPS.fcfx
(47.38 KiB) Downloaded 463 times
Best Regard
Monie
Hi Monie
They return the value in degrees as a float
Monie Jacobsen
Hi Leigh,
They return the value in degrees as a float, I use them;-)
But when I move Miac dsPIC and Miac GPS outside the house, the devices work ....
Is it possible to put an ant on Miac GPS, as well from inside the PCB layout and out of the box???
Best Regard
Monie
Hi Monie,
There is no easy way to do that.
But you could maybe move the GPS module near to a window?
Run the CAN wiring back to the MIAC if that cannot be moved near the window too?
Monie Jacobsen
Hi Leigh,
It is very annoying that an external ant can not be connected :shock:
Best Regard
Monie
