MATRIX MIAC Programmer SW
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team.
I am having an issue with programming a MIAC in the field far away from me :D
The MIAC Connects to the programmer load the hex file(which programs perfectly out of FC7 and FC8) then starting to program but then an error regarding the eeprom is made and the programming stops with the progress bar at the position as you see in the attached ,
What are we doing wrong ? On the other side it says sending completed I am not sure now is the MIAC programmed or not, as it is connected to a very expensive Test rig, I am afraid to start the system not knowing the MIAC is programmed Correctly
Please help :oops:
Re: MATRIX MIAC Programmer SW
Hi Peter
Can you try using mloader instead. Hopefully that should work correctly.
We switched the chip in the miac for a bigger rom size and the old software probably doesn't like big hex files.
QMESAR
Post by QMESAR »
Hi Ben,
Thank you for your info,I will try this today
QMESAR
Post by QMESAR »
Hi Ben.
Thank You M-Loader worked for me in my lab however I have both the EB006V9 and the MIAC USB drivers installed and at my customer only the MIAC USB driver is installed ,which Driver M-loader is using to connect to the MIAC.? :shock: I guess I am asking what driver to supply with M-Loader to the Customer.
Have good time
Hi Peter
It's just the MIAC USB driver that you need for it to work with mLoader.
QMESAR
Post by QMESAR »
Hi Ben.
Thank you very much ,understood this should be ok as they have the MIAC driver installed :D :D
