Problem with Simulation speed for dsPIC
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hi LeighM
Trying to use The Flowcode simulation step and breakpoint functions!
But in Simulation speed I can only set the number "0.25" can choose others but at the start of Simulation it returns to "0.25".
Want to set simulation step to Normal and be able to save the selected number.
Hope you can see what I'm doing wrong ;-)
Isn't there one here! That will describe how Simulation speed can be written and saved and Simulation speed startup = Normal ???????
With dsPIC (MI5809) I try to set Simulation speed to Normal, but always return to number "0.25".
Isn't there anyone who can answer here?
Best Regard
Monie
Has thanked: 481 times
Been thanked: 699 times
Re: Problem with Simulation speed for dsPIC
Hi Monie,
So, if you select Normal, and click OK,
are you saying that the sim speed does not change to Normal, but stays at 0.25?
Monie Jacobsen
Hi LeighM
Have constantly done as you and others describe! But without luck
But stays at 0.25?
Have done what you describe
By a new simulation that starts simulation "0.25"
Even if the layout is saved as "Normal".
Please see attached test file:
MIACdsPIC-Test.fcfx
(23.01 KiB) Downloaded 458 times
Best Regard
Monie
Strange, works for me
Are you able to move the simulation speed slider to the Normal position, and thereby set the speed that way?
(Red arrow)
Monie Jacobsen
Hi LeighM
The Strange,NOT works for me!
(you can move the simulation speed to the normal position. I do this too.)
But once the Flowcode has been restarted. After having the saved setup as you describe "simulation speed"
But stays at 0.25?
Best Regard
Monie
Hello Monie,
Have you changed the simulation speed in the project options? This will set the default speed for the project.
Make sure to save the project after editing the project options and then the change should also persist when reloading the project.
Monie Jacobsen
Hi LeighM
"Make sure to save the project after editing the project options and then the change should also persist when reloading the project."
I do as you describe but without success. But stays at 0.25? on startup again.
Run your Flowcode v6 on server?
Best Regard
Monie
V6? I thought you were using V8?
What do you mean by "on server"?
Is your project file stored on a network share?
If so, do you get the same issue when you store it locally?
Also, is the OK button of the Project Options dialog visible such that you can click it to confirm and save the change?
Monie Jacobsen
Hi LeighM
Again tried to reinstall Flowcode v6
Has set the OK button of the Project Options dialog and save the change.
And now I can simulate the codes;-)
Best Regard
Monie
Monie Jacobsen
Hi LeighM
Thank you very much for your help.
Best Regard
Monie
