Workaround for fround(x,y) for PIC?
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
As it is known that the math function fround(x,y) doesn't work for the PIC family, I was wondering if anyone has a recommended workaround for it?
What I do is convert the float to string, then look at a specific character to see if it is above 5 or not, and if so, add the round to the original number.
But it somehow feels awkward this way, there must be a smarter and more elegant method!
Jan Didden
Linear Audio
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Workaround for fround(x,y) for PIC?
Post by mnf »
How about something like:
Where x is a float argument, y number of digits reqd after the point and temp is an unsigned 32 bit int.
Which will work for float values of limited range (up to a 32 bit integer value when shifted left by the required number of decimal places - which may or may not be helpful?)
Note that this also highlights the fact that floats aren't necessarily exact - try 1.234 to 1 or 2 digits!
jadiflow
Flowcode v5 User
Post by jadiflow »
Thanks Martin, I'll try that. Certainly looks smarter than my method ;-)
Though I am new to the .mul etc format.
Jan
jadiflow
Flowcode v5 User
Post by jadiflow »
Martin, I tried the attached, which should be equivalent to your example, but it does not give what I expected. With an initial value of 1.006 I expect a rounding to 1.01 but I am getting 1.00 . What am I missing?
Jan
(3.28 KiB) Downloaded 2082 times
jadiflow
Flowcode v5 User
Post by jadiflow »
This works, as noted, though feels awkward.
Jan
(11.24 KiB) Downloaded 2079 times
Have you read this post on a different forum?
jadiflow
Flowcode v5 User
Post by jadiflow »
Actually, it is much simpler ...
Just add 0.005 and display only 2 decimals. If the 3rd decimal is > 5, it automagically rolls over to 1.01, if not it remains 1.00 .
Jan
(2.89 KiB) Downloaded 2076 times
jadiflow
Flowcode v5 User
Post by jadiflow »
Hi Medelec, thanks for chiming in. I hadn't seen that post, but as noted above have found an extremely simple solution!
Jan
