Sitronix ST7586
Clive44
Has thanked: 3 times
Sitronix ST7586
Post by Clive44 »
I have a graphic LCD which uses the Sitronix ST7585 driver. Is there anyway I can use Flowcode 8 to control this display?
I am not worried if I have to use a serial or parallel interface.
Clive
Re: Sitronix ST7586
Hi Clive,
You could try the ST7567 component and see if this works. If not then let us know and we can look into it for you.
Clive44
Re: Sitronix ST7586
Post by Clive44 »
The ST7567 seems to be limited to a resolution of 65x132 =8580 bits.
The display I have is the Midas MDCOG240064E6W-FPTLW which uses the ST7585 driver and has a resolution of 240x64 = 15,360 bits.
It's bigger brother, the MDCOG240128B6W-FPTLW has a resolution of 240x128!
So, I don't think the Flowcode ST7567 will work?
Clive
Clive44
Re: Sitronix ST7586
Post by Clive44 »
I have proven an SPI Interface from a PIC18F46K22 (3V3) to an ILI9341 display - see attached photo.
However, when I recompile it using the Flowcode ST7567, as you suggested, the GLCD just stays blank.
I have checked all the SPI signals with an oscilloscope and all the levels are good.
Any help appreciated.
Clive
GLCD_ST7567_Test_1.fcfx
(8.56 KiB) Downloaded 237 times
GLCD_ILI9341_Test_1.fcfx
(9.27 KiB) Downloaded 212 times
Clive44
Re: Sitronix ST7586
Post by Clive44 »
The A0 signal should latch data on the 8th rising edge of SCL (see attached ST7586 datasheet excerpt).
Screenshot of oscilloscope trace shows in practice it only moves every 3 bytes.
Hope this is helpful info.
Clive
Screenshot ST7567 SCL red A0 blue .jpg (84.31 KiB) Viewed 4605 times
ST7586 datasheet excerpt.jpg (66.74 KiB) Viewed 4605 times
Clive44
Re: Sitronix ST7586
Post by Clive44 »
I guess I'm on my own on this one? No help seems to be forthcoming.
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Sitronix ST7586
Post by mnf »
Hi Clive,
If you send me a display - I'll try and get it working. I've just been working with the st7789 and got it to work pretty well...
I can return it when done.
If you're interested I'll pm you my details
Note I'm only offering basic functionality so no simulation . But see the st7789 topic. I got lines, rectangles, multi line text etc working
If it's for s commercial project then payment would be nice :) if it's just for fun that's good too...
