Re: Help regarding compilation error and existing mistakes in my MODBUS programming
mit2003
Been thanked: 2 times
Post by mit2003 »
Hi friends,
Looking for help regarding compilation error and idea / existing mistakes in MODBUS programming.
Thanks in advance.
I am trying to test Master slave communication for past one month. Tried with UART (RS232) but failed and Working with RS485 Multinode method but not reliable.
Realized MODBUS (RS485 - RTU) is the best choice. I google many articles but not get clear idea about MODBUS terminology.
Only "ModbusDemo" can be open, unfortunately can't open "ModBus_Master_Example", "ModBus_Slave_Example", "ModbusMasterDemo" and "ModBusSlaveDemo". If those sample files are accessible, i may get more clarity.
MODBUS Master file created based on "ModbusDemo" and compiled sucessfully.
MODBUS slave file created with the help of online articles (May be did mistakes) and tried to compile but Failed. I can't able to try further and looking for help. I attached Master, SLAVE_1 and SLAVE_2 Files (Just trying to transfer 16 nos of 16 bit data) (PIC18F46K42 with RS485 breakout board) Below one is Error message
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Init_1()
551: INTCONbits.PEIE = 1;
^ (192) undefined identifier "INTCONbits"
^ (196) struct/union required
552: INTCONbits.GIE = 1;
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_Uninit_1()
908: PIE1bits.RCIE = 0;
^ (255) not a member of the struct/union ""
^ (182) illegal conversion between types
int -> volatile union S151
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_UART.c: FC_CAL_UART_UpdateBaud_1()
1564: PIE1bits.RCIE = 1;
1565: INTCONbits.PEIE = 1;
1566: INTCONbits.GIE = 1;
Modbus_SLAVE_2.c: default_isr()
9584: if ((PIR1bits.RCIF) && (PIE1bits.RCIE))
(199) logical type required ^
9591: PIR1bits.RCIF = 0;
int -> volatile union S178
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
FINISHED
Most probably, i may did mistakes. Kindly help me to fix this issue and complete Modbus Testing successfully.
My special thanks to Martin who is my inspiration.
Modbus_SLAVE_2.fcfx
(33.43 KiB) Downloaded 346 times
Modbus_SLAVE_1.fcfx
(33.42 KiB) Downloaded 341 times
Modbus_MASTER.fcfx
(18.94 KiB) Downloaded 324 times
Thank you so much :!:
B.Senthil
Hi mit2003,
I have just successfully compiled with all three of your flowcharts.
The two slaves:
Device:        PIC.18F.18F46K42
Generated by:  Flowcode v8.2.2.15
Date:          Wednesday, April 14, 2021 08:49:10
Users:         1
Registered to: medelec35
License key: 68E2RU
https://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat  18F46K42 "C:\Users\medel\DOWNLO~1\" "Modbus_SLAVE_1"
C:\Users\medel\DOWNLO~1>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F46K42  "Modbus_SLAVE_1.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
using updated 32-bit floating-point libraries; improved accuracy might increase code size
Modbus_SLAVE_1.c: 10062: (2017) config programming has disabled multi-vectors, "irq" in __interrupt attribute/specifier is ignored (warning)
Non line specific message: (2019) low-priority interrupt vector in table @ 0x8 is unassigned, will be programmed with a RESET instruction  (warning)
Memory Summary:
    Program space        used   EF4h (  3828) of  F000h bytes   (  6.2%)
    Data space           used   12Bh (   299) of   FFFh bytes   (  7.3%)
    Configuration bits   used     5h (     5) of     5h words   (100.0%)
    EEPROM space         used     0h (     0) of   400h bytes   (  0.0%)
    ID Location space    used     0h (     0) of    10h bytes   (  0.0%)
    Data stack space     used     0h (     0) of   EC1h bytes   (  0.0%)
You have compiled in FREE mode.
Using Omniscient Code Generation that is available in PRO mode,
you could have produced up to 60% smaller and 400% faster code.
See http://www.microchip.com/MPLABXCcompilers for more information.
Compilation successful!
D:\Flowcode v8\tools\DoNothing\DoNothing.exe
Date:          Wednesday, April 14, 2021 08:49:54
Users:         1
License key: 68E2RU
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat  18F46K42 "C:\Users\medel\DOWNLO~1\" "Modbus_SLAVE_2"
C:\Users\medel\DOWNLO~1>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F46K42  "Modbus_SLAVE_2.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Modbus_SLAVE_2.c: 10062: (2017) config programming has disabled multi-vectors, "irq" in __interrupt attribute/specifier is ignored (warning)
Memory Summary:
    Program space        used   EF2h (  3826) of  F000h bytes   (  6.2%)
    Data space           used   103h (   259) of   FFFh bytes   (  6.3%)
    Data stack space     used     0h (     0) of   EECh bytes   (  0.0%)
FINISHED
Have you made sure your Flowcode version is up to-date?
As you can see from the compiler message, mine is v8.2.2.15
Before compiling I Updated the Full database using Help, Check for Updates...
Changed Files in-use to Full database.
mit2003
Post by mit2003 »
Thank you so much Martin.
One more favor please, shall my approach in the design is okay for communication between Master and Slaves? If not kindly help me to get the right one.
I will update and get back.
B.Senthil
mit2003
Post by mit2003 »
B.Senthil
mit2003
Post by mit2003 »
Actually i got error message, that is why tried these many times.
B.Senthil
Hi, Your welcome.
yes me too.
I have reported the issue.
mit2003
Post by mit2003 »
Hi Martin and Benj,
After update to current version, Yes compiled successfully.
Thank you very much Martin and Benj.
Modbus example projects are not accessible. Kindly provide those files in accessible manner which will help me, how to implement my expected task efficiently.
I am not sure that my flow in the master and slave files are even valid one or not. Its great help if you can spend some free time for this request.
B.Senthil
Mim
Post by Mim »
Good evening.
Help solve the problem with Modbus RTU.
The master sends the request, the slave receives it correctly and executes it.
The slave sends a response is not correct. (Only the low byte)
Mim
Post by Mim »
Dear Benj.
Tell me so it should be in Modbus RTU RS485, or is it a bug?
FC 9 components have been updated.
Mim
Post by Mim »
Dear Benj.
