15V Voltmeter at 3v3 mcu (SOLED)
bercioiu
Has thanked: 90 times
Been thanked: 34 times
Post by bercioiu »
Hi guys! I need your help again!
I want to make a voltmeter for my car and I can't handle with math ...
Mcu I use is 18F26K20, powered at 3.3 v, powered by the car's electrical installation through a stabilizer ld111733.
1) What values should the divider resistors have (R1, R2) ?
2) What should the adc reading calculation look like?
I've attached the FC8 file I want to work on.
Thank you!
+15V
R1
---- ADC
R2
--- Gnd
Thank you!
WhatsApp Image 2022-04-07 at 7.44.34 AM.jpeg (63.01 KiB) Viewed 13248 times
Voltmeter_3v3.fcfx
(10.9 KiB) Downloaded 319 times
Re: 15V Voltmeter at 3v3 mcu
I have moved your post from Programming Tips & Tricks as that section is for sharing tips and not starting with a question.
I have calculated R1 to be 33K & R2 to be 8K2
This is handy as they are common preferred values.
Then if the voltage goes above 15V,the ADC of the PIC will be protected.
As for your flowchart just place * 5.0 at the end of your fomula so you will have
MeasuredVoltage = 3.3 / 1024.0 * IntADC * 5.0
Note 15V in the top or R1 = 3V on the ADC pin.
This gives you a bit of leeway in voltage tolerance.
bercioiu
Re: 15V Voltmeter at 3v3 mcu (SOLED)
Post by bercioiu »
Thanks again for your help, Martin!
I put the resistors as you said and everything goes very well, everything is linear! There are no differences in different voltages.
When you have some free time, can you explain to me why " * 5 " ?
Later edit: I think I understand, 5 is the ratio between the input voltage and the adc voltage, after the divider.
You're welcome, I'm glad the values worked for you as it was only theory.
bercioiu wrote: ↑
Fri Apr 08, 2022 6:57 am
Yes, that is correct.
As the voltage going into the top of the R1 is five times higher than the voltage going into the ADC, the display has to show five times ADC voltage.
The ratio is five as you correctly stated.
If you want the precise ratio the maths are
1/(R2/(R1 + R2))
= 5.024
That is why the display voltage values match (or very near to) the actual voltage values.
bercioiu
Post by bercioiu »
For fine tuning, I formed R1 from 10k adjustable and 27k fixed, and I adjusted the potentiometer until I read the measured value with a reliable voltmeter.
Yes, that is a good way.
The alternative is to measure the two resistances, then plug the values in the above formula since resistors do have tolerances.
Then you can use that for that * value at the end of your formula.
