Compile to hex error with no custom code
kdoney34711
Has thanked: 1 time
Post by kdoney34711 »
I keep getting the following error whenever I attempt to compile to hex a project which has no custom code:
File name: C:\Users\kdoney\Desktop\electronics\pic\miac\miac_lathe.c
Generated by: Flowcode v4.1.1.55
Date: Sunday, October 18, 2009 13:49:55
Licence: Professional
Registered to: Kevin Doney
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "miac_lathe.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
miac_lathe.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe C:\Users\kdoney\Desktop\electronics\pic\miac\miac_lathe.c -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC18F4455 -la -c2 -o C:\Users\kdoney\Desktop\electronics\pic\miac\miac_lathe.pp -v -d _BOOSTC -d _PIC18
C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include\PIC18F4455.h(9): Illegal directive
C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include\boostc.h(12): Illegal directive
2 errors detected
Error: preprocessing error
failure
Return code = 1
FINISHED
It compiles to c just fine. I can see no error in the code. If I create a new project with miac selected and do nothing other than try to compile to hex I get the same errors.
PIC18F4455.h
(60.59 KiB) Downloaded 433 times
boostc.h
Error on line 12?
(4.68 KiB) Downloaded 475 times
miac_lathe.fcf
main file V4 latest version
(15.78 KiB) Downloaded 428 times
Re: Compile to hex error with no custom code
I have just tried to compile the program here and it is working fine. It is strange that the compiler thinks the problem is inside the BoostC resource header files. It may be worth trying to uninstall and reinstall to see if this fixes the problem your having.
kdoney34711
Has thanked: 1 time
That did it thanks. :lol:
