problem compiling for 10F
- NOPROBLEM48
I can not compile the elementary project on 10F222. Transferred on other chips of a series 10F also it is not compiled. And here if to transfer on 12F all is compiled normally.
- FlechX.fcf
- (5 KiB) Downloaded 380 times
- NOPROBLEM48
Re: problem compiling for 10F
Thanks, Steve! As I have understood, now Flowcode cannot make HEX automatically. You how I am able to do it manually could not tell?
- NOPROBLEM48
Thanks Steve! Thanks to article has left HI-TECH compiler and all has earned!
- NOPROBLEM48
Could not compile the project on chip PIC12F683. The Same project on PIC10F206 was compiled normally. I have tried to restore installation from a disk, but also could not.
- The compiler message
- NoFile.jpg (57.41 KiB) Viewed 11112 times
- The message at restoration
- Error.jpg (8.6 KiB) Viewed 11112 times
I have just tried compiling a project for the 12F683 using the HITECH compiler on V4 of Flowcode and the program compiled correctly. Would it be possible for you to send me your file so I can find out what is causing your compilation problem.
- NOPROBLEM48
Ok I see the problem it seems you are using a version of Flowcode that does not have the HITECH compatibilities built into it. In your generated C file it says you are running 4.2.3.58 which is the latest version that should have all the HITECH additions. However it seems that the chip you are using does not have this new information so maybe you are using a beta copy of 4.2 etc. We will be releasing an updated version hopefully this week that should tie up all these problems.
For now you should be able to replace the FCD file in your installation to fix this problem.
Let me know how you get on.
- 12F683.fcd
- (5.59 KiB) Downloaded 406 times
- NOPROBLEM48
- NOPROBLEM48
One more failure with compilation! It has arisen after I have added in the scheme connection point. Change of labels and names on the English has not helped!
- TEST.ZIP
- (20.91 KiB) Downloaded 390 times
- NOPROBLEM48
Road Steve, all not so is simple! I suspected it, and have corrected on English all words, that only could! But all the same in C the text there were pieces with?????
That is in the Russian version I could not use connection point.
