RXINT and 18F4331
Frank123
Has thanked: 1 time
RXINT and 18F4331
Post by Frank123 »
I recently use Flowcode V4 and therefore I get .fcf Flowcode of V3.
Unable to run RXINT. I do a lot of change in the .fcd but the only one that works is to resume my old version (find on this forum) :
[USART_RX]
Name="Réception USART"
UseExplicitHandlerCode=1
FlagReg=
FlagBit=
HandlerCode="if (pir1 & (1 << RCIF))\n{\n  FCM_%n(); // call selected macro\n}\n"
UseExplicitEnableCode=1
EnReg=
EnBit=
EnableCode="intcon.PEIE = 1; // Enable peripheral interrupts\nintcon.GIE = 1;  // Enable global interrupts\npie1.RCIE = 1;   // Enable USART receive interrupts\nrcsta.CREN=1;    // Enable reception\n"
DisableCode="pie1.RCIE = 0; // Disable USART receive interrupts\n"
OptCnt=0
TmrOpt=0
Frank
Electronics teacher
Re: RXINT and 18F4331
Please post your current V4 FCD file and the old V3 FCD file (with your modifications) and we'll try to create a new V4 one for you.
Frank123
Has thanked: 1 time
Post by Frank123 »
V3 FCD File
18F4331.fcd
PIC18F4331 V3
(12.46 KiB) Downloaded 326 times
V4 FCD File
18F4331.fcd
PIC18F4331 V4
(8.48 KiB) Downloaded 348 times
Only USART_RX (add by me) is ok on this.
Frank
Electronics teacher
You might want to try the st_bit() and cr_bit() functions instead of using the "dot" notation.
Do you get specific error messages when compiling, or is the program compiling ok but not working as expected?
Frank123
Has thanked: 1 time
Post by Frank123 »
the program compiling ok but not working as expected with "RXINT" and it's working well with "Réception USART".
Is't possible to me to change in c code and recompil directly ? How to ?
Frank
Frank
Electronics teacher
Hi Frank,
Aaah, I see the problem now - sorry I was slow on the uptake.
It looks like the EnableCode entry of the RXINT function might need to change from this:
EnableCode="st_bit(pie1, RCIE);\n"
...to this...
EnableCode="st_bit(intcon, PEIE);\nst_bit(pie1, RCIE);\n"
Frank123
Has thanked: 1 time
Post by Frank123 »
Non ça ne marche pas. C'est la première chose que j'ai essayé.
Frank
Electronics teacher
The RXINT interrupt allows for incoming data to interrupt the program so you can pull it from the incoming UART buffer and process it straight away ready for the next incoming byte.
When the PIC device starts up it enables the UART interface but the receive function is switched off.
Calling the ReceiveByte macro at the start of your program before enabling the interrupt will enable the receive function and your interrupts should work from then on.
Frank123
Has thanked: 1 time
Post by Frank123 »
thank you Ben,
it works with it.
I do not understand why one RS232Send is needed before initializing the interrupt but I would look at the C.
Frank
Frank
Electronics teacher
