I am and have been for some time using Flowcode Ver 3.
I have just struck a problem whereby I am unable to generate the asm file and get the following error message.
________________________________________________________________________________________________
FATAL: Unable to create output file: Duty Cyle Test-A.pp
Error: preprocessing error
failure
Return code = 1
FINISHED
Whilst this program does not contain any imbedded C code the previous project did.
Can you please advise how to resolve this problem.
Many thanks.
Unable to compile
Re: Unable to compile
The FRAQ refernces Windows 7 and I am running XP but I did manage to resolve the problem by saving to another directory.
Hello Terry,
Thanks for letting me know your up and running correctly now.
Thats strange that XP now has the problem though. Are you using SP3 of XP by any chance?
keshav@solus.in
I am using PIC16F1933 micro controller,
when i was compiling flow code program into HEX file i am getting following error bellow in blue lines ,
please suggest me how to solve this problem for your kind reference i have attached flowcode program
please reply as soon as possible.
File name: E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c
Generated by: Flowcode v4.3.7.63
Date: Wednesday, September 15, 2010 17:13:43
Licence: Professional
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F1933 "16f1933-testing.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
16f1933-testing.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F1933 -la -c2 -o E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.pp -v -d _BOOSTC -d _PIC16
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(83:2): error: unknown identifier 'ansela'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(83:2): error: invalid operand 'ansela'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(83:9): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(84:1): error: unknown identifier 'anselb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(84:1): error: invalid operand 'anselb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(84:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(88:2): error: unknown identifier 'option_reg'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(88:2): error: invalid operand 'option_reg'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(88:13): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(93:2): error: unknown identifier 'option_reg'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(93:2): error: invalid operand 'option_reg'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(93:12): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(94:2): error: unknown identifier 'osccon'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(94:2): error: invalid operand 'osccon'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(94:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(95:2): error: unknown identifier 'osctune'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(95:2): error: invalid operand 'osctune'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(95:9): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(96:2): error: unknown identifier 'pcon'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(96:2): error: invalid operand 'pcon'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(96:6): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(97:2): error: unknown identifier 'porta'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(97:2): error: invalid operand 'porta'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(97:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(98:2): error: unknown identifier 'portb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(98:2): error: invalid operand 'portb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(98:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(99:2): error: unknown identifier 'portc'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(99:2): error: invalid operand 'portc'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(99:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(100:2): error: unknown identifier 'trisa'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(100:2): error: invalid operand 'trisa'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(100:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(101:2): error: unknown identifier 'trisb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(101:2): error: invalid operand 'trisb'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(101:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(102:2): error: unknown identifier 'trisc'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(102:2): error: invalid operand 'trisc'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(102:7): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(103:2): error: unknown identifier 'adcon0'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(103:2): error: invalid operand 'adcon0'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(103:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(104:2): error: unknown identifier 'adcon1'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(104:2): error: invalid operand 'adcon1'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(104:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(109:2): error: unknown identifier 'trisa'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(109:2): error: invalid operand 'trisa'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(109:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(111:2): error: unknown identifier 'porta'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(111:2): error: invalid operand 'porta'
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(111:8): error: failed to generate expression
E:\TESTING-CODE\flowkit-testing-08-09\16f1933-testing.c(111:2): error: error in the body of 'if' expression
16f1933-testing.c success
failure
Return code = 1
FINISHED
16f1933-testing.c
failure
Return code = 1
FINISHED
- 16f1933-testing.fcf
- (4 KiB) Downloaded 888 times
Hello keshav@solus.in
The 16F19XX can only be compiled with Flowcode V4 using Hitec compiler and not the default BoostC compiler.
See: http://www.matrixmultimedia.com/mmforum ... =26&t=6812
keshav@solus.in
hello
presently i am using PIC 16F1933 micro controller ,
I have following query about flow code programming for 16F1933 pic micro controller,
1)Register configuration is necessary for RS232 communication for PIC16F1933 micro controller,
2) for 16F1933 pic micro controller compiler is HI TECH-C compiler but not with default Boost c compiler,
any other setting is there for HITECHC compiler and 16F1933 microcontroller in flowcode program,
3) i written flowcode program to send and receive char using UART,
PIC16F1933 development board is sending character but it is not receiving ,
4)same program working fine with 18F8722 PIC micro controller,
5) for your kind reference i have attached flowcode program,
6)why pic 16f1933 is not compiling using default boostc compiler
regarding this issue yesterday i posted in your forum but no one be respond,
- String RECEIVE.fcf
- (8 KiB) Downloaded 883 times
Hello Keshav,
We are not replying to you because you are asking Flowcode v4 questions in a non Flowcode v4 topic. Please post your questions in the appropriate place and they will be answered.
The device you are using is very new and as such is not part of BoostC at the moment.
I have encountered a simmilar problem with compilation
"preprocessing error return code 1".So I checked the topic referenced in the 2010 topic and moved the file to another folder in Windows 7 without any change.
I also also get a message "Unable to open include file:math.h.
In fact my entire flowchart is a C-code icon between the Start/End icons to try out a fairly lengthy calculation.
Since seeing the second message I searched the Boostc folder for the include file math.h and was unable to find it.
I bought the Flowcode Prof. disc some 5 years or more ago
