Flow code v4 will support following Microcontroller PIC 16F1516 and PIC16F1947,PIC16F1946.
I checked in Microcontroller list but those microcontroller is not in that list.
please suggest me how to add new microcontroller in flowcode v4.
Thanks & Regards
Keshavamurthy
Microcontroller number is not list
Re: Microcontroller number is not list
Here are the FCD files for two of the chips, the third is not currently supported at all. Please note that they will not currently work with the default BoostC compiler so you will have to switch over to HiTech to use these devices. Instructions of how to do this are available from here.
http://www.matrixmultimedia.com/mmforum ... =26&t=6812
To add the FCDs simply copy the files below into your Flowcode v4/FCD directory.
- 16F1947.fcd
- (10.91 KiB) Downloaded 282 times
- 16LF1946.fcd
- (10.91 KiB) Downloaded 255 times
