C Code Error but dont use C Code HELP
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Hi, All
I Have A really stranges problem with flowcode.
When I try to compile my program into my chip It gives me a error:
Launching the compiler...
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F877A "Aquarium Controller Version 011-a00.c"
Return code = 1
Flowcode kan de C-code niet vertalen vanwege de volgende fout:
Als de flowchart C-code bevat, controleer die dan zorgvuldig. Als de flowchart geen C-code bevat of als die gegarandeerd vrij is van fouten, neem dan contact op met de technische ondersteuning.
FINISHED
I dont understand because I dont use any C code block.
Hope some body can check it for me because I cant see the problem.
Regards Jordy
(43.02 KiB) Downloaded 228 times
Aquarium Controller Version 011-a00.fcf
(24.32 KiB) Downloaded 237 times
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: C Code Error but dont use C Code HELP
Post by JohnCrow »
Hi Jordy
Try this one
Aquarium Controller Version 011-a00-corrected.fcf
(24.33 KiB) Downloaded 303 times
You had not set up the last icon(stop icon) in the ds1307 macro
Just tried a compile to hex and it doesnt give errors now
Hope it works for you now
Jordy101091
Thank you verry much John, It works fine know.
Regards Jordy
JohnCrow
Post by JohnCrow »
Your welcome, glad to be able to help
