Hi LeighM,
Today I have started developing the code for analog channels with STM32F303VCT6 components and I found some mismatch in ADC pins. Please help to check.
Below are the details:
As per datasheet STM32F303VCT6 MCU has 39 channel ADC. But Flowcode component has only 9 Ch ADC.
In our project, we used all the ADC AI pins in both Chip. So please help to resolve these issues. Thanks.
Below is the datasheet link.
https://www.st.com/resource/en/datashee ... f303vc.pdf
Karthick.
STM32F303VCT6 component ADC Pin's issue
karthickefy
- Has thanked: 4 times
- Been thanked: 9 times
- STM32F303VCT6 very less ADC.PNG (45.06 KiB) Viewed 4941 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: STM32F303VCT6 component ADC Pin's issue
Please let me know how you get on with the 32F446ZC ADC updates,
if they are OK I will see if 32F303VC can be updated in a similar way.
karthickefy
HI LeighM,
Can you please update the ADC ports for STM32F303VCT6 component too? I will check with our product and update you on the test result. Thanks.
Karthick.
Karthick.
- LeighM
Please try these ...
- 32F303VC.fcdx
- (52.99 KiB) Downloaded 231 times
- STARM_CAL_ADC.c
- (35.98 KiB) Downloaded 250 times
karthickefy
Hi LeighM,
Today I have tried to develop the ADC for STM32F303VCT6 MCU and I found that, all ADC pin's are not enabled. Because STM32F303VCT6 has 39 ADC channels. but our Flowcode shows only 9 ports. Can you please help to modify the same?
https://www.st.com/resource/en/datashee ... f303cb.pdf
Karthick,
Karthick,
- stm32f303vc adc.PNG (202.35 KiB) Viewed 4840 times
- LeighM
You need to download and use the files I posted earlier ...
STARM_CAL_ADC.c goes into directory C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM
32F303VC.fcdx goes into directory C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARM
If you subsequently do an update these files will be marked as not genuine, untick the box to ensure they don't get over-written.
Once you have confirmed that these changes are OK for you, I will get these updated files into our auto-update system.
Hope that makes sense.
Leigh
Leigh
karthickefy
Hi LeighM,
Thanks.I followed your instruction and now I can see all the ADC pin's.
Thanks.
Thanks.
- ADC.PNG (62.99 KiB) Viewed 4824 times
karthickefy
Hi Leighm,
Can you please help to update STARM_CAL_ADC.c files to auto update system? I have tested and it is working fine. Thanks.
LeighM wrote: ↑Fri Jul 31, 2020 8:33 amHi,
Leigh
