STM32F303VCT6 component ADC Pin's issue
karthickefy
Has thanked: 4 times
Been thanked: 9 times
Post by karthickefy »
Hi LeighM,
Today I have started developing the code for analog channels with STM32F303VCT6 components and I found some mismatch in ADC pins. Please help to check.
Below are the details:
As per datasheet STM32F303VCT6 MCU has 39 channel ADC. But Flowcode component has only 9 Ch ADC.
In our project, we used all the ADC AI pins in both Chip. So please help to resolve these issues. Thanks.
Below is the datasheet link.
https://www.st.com/resource/en/datashee ... f303vc.pdf
Karthick.
STM32F303VCT6 very less ADC.PNG (45.06 KiB) Viewed 4413 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: STM32F303VCT6 component ADC Pin's issue
Post by LeighM »
Please let me know how you get on with the 32F446ZC ADC updates,
if they are OK I will see if 32F303VC can be updated in a similar way.
karthickefy
HI LeighM,
Can you please update the ADC ports for STM32F303VCT6 component too? I will check with our product and update you on the test result. Thanks.
Karthick.
LeighM
Post by LeighM »
Please try these ...
32F303VC.fcdx
(52.99 KiB) Downloaded 205 times
STARM_CAL_ADC.c
(35.98 KiB) Downloaded 222 times
karthickefy
Hi LeighM,
Today I have tried to develop the ADC for STM32F303VCT6 MCU and I found that, all ADC pin's are not enabled. Because STM32F303VCT6 has 39 ADC channels. but our Flowcode shows only 9 ports. Can you please help to modify the same?
https://www.st.com/resource/en/datashee ... f303cb.pdf
Karthick,
stm32f303vc adc.PNG (202.35 KiB) Viewed 4312 times
LeighM
Post by LeighM »
You need to download and use the files I posted earlier ...
STARM_CAL_ADC.c goes into directory C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\STARM
32F303VC.fcdx goes into directory C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARM
If you subsequently do an update these files will be marked as not genuine, untick the box to ensure they don't get over-written.
Once you have confirmed that these changes are OK for you, I will get these updated files into our auto-update system.
Hope that makes sense.
Leigh
karthickefy
Hi LeighM,
Thanks.I followed your instruction and now I can see all the ADC pin's.
Thanks.
karthickefy
Hi Leighm,
Can you please help to update STARM_CAL_ADC.c files to auto update system? I have tested and it is working fine. Thanks.
LeighM wrote:
Fri Jul 31, 2020 8:33 am
Leigh
LeighM
Post by LeighM »
Thanks for confirming.
I've updated these already :)
So you can run the full update.
Leigh
