Memory Usage Report
beambase
Has thanked: 6 times
Been thanked: 8 times
Memory Usage Report
Post by beambase »
When I complie my project my Message.txt file used to look like this:
C:\Program\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "Panel8490d.obj" -t PIC18F8490 -d "C:\Documents and Settings\BjΓ¶rn\Mina dokument\Flowcode\skarp2" -p "Panel8490d"
BoostLink Optimizing Linker Version 6.95
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCD_LCDDisplay0_PrintASCII in: Panel8490d.c
FCD_LCDDisplay0_Command in: Panel8490d.c
FCD_LCDDisplay0_ScrollDisplay in: Panel8490d.c
FCD_LCDDisplay0_ClearLine in: Panel8490d.c
FCD_LCDDisplay0_RAM_Write in: Panel8490d.c
Building CASM file
Memory Usage Report
RAM available:768 bytes, used:144 bytes (18.8%), free:624 bytes (81.2%),
Heap size:624 bytes, Heap max single alloc:127 bytes
ROM available:16384 bytes, used:9872 bytes (60.3%), free:6512 bytes (39.7%)
success
Return code = 0
FINISHED
After adding the CAN component, the Message.txt looks like this, no Memory Usage Report:
C:\Program\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "Panel8490e.obj" -t PIC18F8490 -d "C:\Documents and Settings\BjΓ¶rn\Mina dokument\Flowcode\skarp2" -p "Panel8490e"
Return code = 0
FINISHED
I am using some custom CAN code supplied in this thread:
http://www.matrixmultimedia.com/mmforum ... =22&t=6603
Is there a way to get the Memory usage report back?
Bjorn
Eric
Been thanked: 1 time
Re: Memory Usage Report
Post by Eric »
I noticed the same problem and I didn't used the CAN component.
Rgds,
Eric
I have checked on the Sourceboost forums and cant seem to find a valid explaination for this at the moment. Can you replicate this problem. eg using certain components or does it seem to be more hit and miss then that?
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
Hello Benj
I received nearly the same warning if i work with the delay component.
Regards Wolfgang
(110.55 KiB) Downloaded 904 times
Eric
Post by Eric »
I think the problem appears the moment there are certain errormessages from the assembler/linker.
If no errormessage, you see the memory usage.
If there is an errormessage, it looks that the memory status is overwritten by the error.
Rgds,
Eric
