Getting PIC32MZ connected
An area to discuss 32-bit PIC specific problems and examples
streammaster
Has thanked: 7 times
Been thanked: 13 times
Post by streammaster »
Hi Guys,
I'm looking to get the Microchip starter kit board PIC32MZ.
http://www.microchipdirect.com/ProductS ... s=DM320007.
I can not find how and if the FC7 supports USB programming (programmer)?
I use to use PIC18 and PICkit 3 to program the target and this works relatively smoothly.
Can anyone confirm that this would work (using USB) so I can Compile to the board from FC?
The chip of interest is PIC32MZ0512EFE064.
Thanks,
Igor
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Getting PIC32MZ connected
Post by QMESAR »
Please post your issues in the relevant forums PIC32 has a dedicated forum for PIC32 so does all other families.
If you read the board manual you will notice the the board has a connector footprint J2 which is for PICkit3 ,PICKIT3 is supported within FC
the board on board programmer is not supported directly with in FC
http://ww1.microchip.com/downloads/en/D ... 05230B.pdf
The answer to your question is yes this board can be used with FC by using the PICKIT3 programmer
:D
streammaster
Hi Qmesar,
thanks for prompt reply.
Now when I had a look in tot he schematic it is the PICkit interface. In the manual is mentioning as debbuger interface, so it was confusing.
The board communicates with USB to MPLAB.
Thank you very much for clarifying it. I ordered the board and multimedia extension board. It will be fun :) .
Igor
QMESAR
Post by QMESAR »
Just take note of this jumper setting when using your PICKIT3
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi Igor,
I think the J7 connector is the right one, if you use PICKIT3.
Best Regards,
Lagoda
(224.33 KiB) Downloaded 3692 times
QMESAR
Post by QMESAR »
Hi looking at the manual closer now you are correct it is J7 :D
