Hi Guys,
I'm looking to get the Microchip starter kit board PIC32MZ.
http://www.microchipdirect.com/ProductS ... s=DM320007.
I can not find how and if the FC7 supports USB programming (programmer)?
I use to use PIC18 and PICkit 3 to program the target and this works relatively smoothly.
Can anyone confirm that this would work (using USB) so I can Compile to the board from FC?
The chip of interest is PIC32MZ0512EFE064.
Thanks,
Igor
Getting PIC32MZ connected
streammaster
- Has thanked: 7 times
- Been thanked: 13 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Getting PIC32MZ connected
Please post your issues in the relevant forums PIC32 has a dedicated forum for PIC32 so does all other families.
If you read the board manual you will notice the the board has a connector footprint J2 which is for PICkit3 ,PICKIT3 is supported within FC
the board on board programmer is not supported directly with in FC
http://ww1.microchip.com/downloads/en/D ... 05230B.pdf
The answer to your question is yes this board can be used with FC by using the PICKIT3 programmer
- 1.jpg (28.55 KiB) Viewed 16904 times
Regards QMESAR
Regards QMESAR
streammaster
Hi Qmesar,
thanks for prompt reply.
Now when I had a look in tot he schematic it is the PICkit interface. In the manual is mentioning as debbuger interface, so it was confusing.
The board communicates with USB to MPLAB.
Thank you very much for clarifying it. I ordered the board and multimedia extension board. It will be fun
Igor
Igor
- QMESAR
Just take note of this jumper setting when using your PICKIT3
- 1.jpg (196.79 KiB) Viewed 16894 times
Regards QMESAR
Regards QMESAR
Hi Igor,
I think the J7 connector is the right one, if you use PICKIT3.
Best Regards,
Lagoda
Best Regards,
Lagoda
- (224.33 KiB) Downloaded 3692 times
- QMESAR
Hi looking at the manual closer now you are correct it is J7
Regards QMESAR
Regards QMESAR
