Bug version 4 to version 5
cubitus54
Flowcode v5 User
Has thanked: 7 times
Been thanked: 32 times
Post by cubitus54 »
I developed a program with temperature sensors (DS18B20) with version 4 of Flowcode. It works very well.
I loaded the same program with version 5 of Flowcode. The temperatures indicated by the different sensors are the same ...
Is my program or Flowcode :?:
thank you
DS18B20 temp_3_v4.fcf
(20.5 KiB) Downloaded 296 times
DS18B20 temp_3_v5.fcf
(30.98 KiB) Downloaded 313 times
Flowcode V6.1.2.0(11 05 2015)
Re: Bug version 4 to version 5
Please could you attach the C files for your v4 and v5 projects and we can them compare the two files and see if there are any issues there.
cubitus54
Flowcode v5 User
Post by cubitus54 »
Ok
Thank
DS18B20 temp_3_v5.c
(38.03 KiB) Downloaded 291 times
DS18B20 temp_3_v4.c
(42.67 KiB) Downloaded 276 times
I have had a good compare of the C files and they both look correct to me. The only differences seem to be very minor changes to the way the I/O is working.
In v4 we were setting and clearing the data direction and port registers directly.
In v5 we have functions to do this for us. I suppose the timing may be being effected very slightly?
I see your running the device at 8MHz. Is this using the internal oscillator or using a crystal. If your using a crystal then maybe try upping the frequency and seeing if this helps.
Benj wrote:Is this using the internal oscillator or using a crystal.
Hi Ben, looking at the configuration settings. internal osc is used.
cubitus54
Flowcode v5 User
Post by cubitus54 »
I tried a ocillator at 16MHz
It's the same thing ... :?
I think the problem is at this level
oo_read_device(capteur)
Get_Temp=DS1820_get_temp()
cubitus54
Flowcode v5 User
Post by cubitus54 »
I still have not advanced.
I tried with a 29MHz clock.
Still the same problem.
thank you
cubitus54
Flowcode v5 User
Post by cubitus54 »
Is there a solution for run multiple sensors with Flowcode V5?
Is there a C code that could replace the function?
Thank you.
