I am programming a 18F8490 that has Port J. But in the Flowcode you can only select Port A > Port I. Port I does not exist on the 18F8490.
Any fix for this?
Port J ???
Re: Port J ???
Here is an updated FCD file. Please can you confirm if it fixes your problem.
- 18F8490.fcd
- (11.26 KiB) Downloaded 256 times
Re: Port J ???
no... the problem is nowthat if I use a dialouge box to set a connection to Port J... I can't. The dialouge box stille shows Port A > I and when I i selected, a diolouge shows saying that "Port I does not exist on this device"
Re: Port J ???
Ok I think I have fixed it now.
- 18F8490.fcd
- (11.26 KiB) Downloaded 269 times
Re: Port J ???
Looks good in Flowcode but when compiling I get the following errors:
Panel8490b.c(573:2): error: unknown identifier 'trisi'
Panel8490b.c(573:2): error: invalid operand 'trisi'
Panel8490b.c(573:8): error: failed to generate expression
Panel8490b.c(574:13): error: unknown identifier 'porti'
Panel8490b.c(574:13): error: invalid operand 'porti'
Panel8490b.c(574:19): error: failed to generate expression
Panel8490b.c(574:19): error: invalid operand '& '
Panel8490b.c(574:27): error: failed to generate expression
Panel8490b.c(574:27): error: invalid operand '=='
Panel8490b.c(574:9): error: failed to generate expression
Panel8490b.c success
failure
Return code = 1
failure
Return code = 1
Re: Port J ???
Have you changed the registers from porti to portj?
I just created a simple test program to output 0 to port j and the code compiled correctly.
Here is the compiled C code.
//Output
//Output: 0 -> PORT J
trisj = 0x00;
portj = 0;Regards Ben Rowland - MatrixTSL
