Component: IrDA (EB012, MCP1250, MCP2120) (Wireless)
Revision as of 10:55, 6 March 2014 by BenR (talk | contribs) (→‎Examples)
Author Matrix Ltd.
Version 1.1
Category Wireless
Image IrDA (EB012, MCP1250, MCP2120) component
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface.
FC6 Icon.png IrDA Transmit
Receive
Basic example which waits for any incoming data and then displays the data on the LCD.
FC6 Icon.png IrDA Receive
SendChar
INT Char
ReceiveChar
INT Timeout
INT
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
INTERFACE
This property is of type Fixed list of ints and can be referenced with the variable name INTERFACE.
Echo
This property is of type Fixed list of ints and can be referenced with the variable name ECHO.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
