What's New
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
New features in Flowcode v11.0.2
Flowcode v11.0.2 was released in June 2026 and includes the following new features:
Label and Jump icon improvements
Connection Point icons have been renamed to "Label" and "Jump", and the latter has been extended to include 'break', 'continue' and 'return' jump types (as well as the usual 'goto' type).
This allows programs avoid the use of the 'goto' jump type, e.g. by breaking out of loops or returning early within a macro.
Loose casting in Web Developer projects
Web Developer projects create JavaScript as opposed to the C code generated by Embedded projects. Flowcode now allows more flexibility when using variables as parameters and return types, in keeping with JavaScript's typecasting rules.
Copying text-based macros
Copying from text-based macros (i.e. Code and Pseudocode macros) now copies the actual text displayed.
This makes it much easier to copy code from a project into a text document or external IDE.
Breakpoints and Bookmarks can be toggled during simulation
In previous versions, simulation needed to be paused or stopped to adjust the breakpoints. But now in v11.0.2, breakpoints and bookmarks can be toggled even when simulation is running.
More information about the changes in this release can be found here:
 https://www.flowcode.co.uk/forums/viewtopic.php?t=3759
New features in Flowcode v11.0.1
Released in March 2026, Flowcode v11.0.1 includes the following new features:
Blueprint Macros
Blueprint macros are simple, codeless macros that can be used to document a process associated with the Flowcode project.
They can also be used to sketch out an idea for a new macro as they can be converted into a code macro once its initial design is complete.
More details can be found on the Blueprints page.
COM Port Autodetection
The serial port COM number used by Eblocks boards and some other boards can now be autodetected.
Variables definitions can be copied and pasted
Variables and constants can now be copied from the lists in Project Explorer. These can then be pasted into the same list or another list (including a variable list in another project).
Pasting a variable definition will show the Add New Variable window, allowing the variable name and other information to be altered.
In-app browser links can be opened in external browser
When viewed within Flowcode, browser links such as those in this wiki and the Flowcode forum can be opened in an external browser via the context menu (i.e. by right-clicking the link and selecting "Open link in external browser".
History comment displayed in Library Update dialog
The Library Update window now shows a "Details" column for each update (e.g. component or chip definition). This usually contains a brief description of what is new in the currently selected version of that update.
A larger list of the changes in this release can be found here:
 https://www.flowcode.co.uk/forums/viewtopic.php?t=3659
New features in Flowcode v11.0.0
The first major release of Flowcode v11 was released in October 2025 and a list of the new features follows:
Graphical Display Design Tools
New for version 11 is a full library of components for driving touch screen graphical displays: display drivers for the most popular touch screens, graphics widgets, graph widgets, touch screen components, WYSIWYG graphical display designer and menu control subroutines. These allow you to design touch screen graphical displays based on any 8, 16, or 32 bit microcontroller.
Web Mirror
The Web Mirror features allows you to mirror the functionality of you touch screen system on any browser anywhere in the world. This is only available on the E-Blocks 3 hardware for now. The great benefit is that you can use your mobile phone to control your electronic projects.
No coding is needed. It's just a couple of settings on the Graphical display component. Flowcode takes care of all the details.
New Project Wizard and Auto-detect
Getting started is so hard. So many options, choices, settings in our beautiful complex world. The new project wizard provides a menu system that makes this easier for all users showing options and guiding users through choices.
If you have E-Blocks 3 hardware then it is even easier: Flowcode sees what upstream and downstream boards you have connected and sets up the program for you.
Serial Debugging on Hardware
Serial debugging allows you to pause your program as it runs in hardware and see the status of variables in your project. You can set breakpoints in your code and change the values of variables while program execution is paused.
Serial debugging was only available on Matrix hardware in V10. In V11, Serial debugging now works on third party hardware that has a serial COM port available via USB. This includes many Arduino, ESP32 and PIC boards.
E-Blocks 3 and Auto-id
The goal is simple: create the best environment for developing electronic projects. Its hard to separate the hardware from the software sometimes. The combination of Flowcode and E-Blocks 3 provides an amazing development platform for both educators and industrial engineers.
Each E-blocks downstream board has a small microcontroller on it. These communicate to the upstream board to inform Flowcode what hardware is connected. This allows Flowcode to put the appropriate components on the 2D panel with all the right settings, making project setup much easier!
New Microcontrollers
The world does not stand still. Manufacturers are constantly adding new microcontrollers with more features, smaller silicon areas, faster clock rates and so on.
We constantly add new microcontrollers to the chip lists. A lot of work has been done recently to add the Microchip PIC8 Q range.
Flowcode is now compatible with 1,789 microcontrollers.
2D Panel Updates
The 2D panel has been upgraded so that it is now possible to zoom in and out on all component views.
A new rich text components adds formatted text to components and panels, and all panel objects now can be anchored to the panel sides or even set to display completely in the panel (e.g. for showing charts in a separate window).
New features include:
New Coding Features
A variety of new features have been added to make coding in Flowcode v11 even simpler than before.
Direct string comparisons can now be made in decision icons, the loop command has a "loop forever" option and several new operators (e.g. increment/decrement and assignment) have been added to make Flowcode calculations more representative of C code.
  • Direct string comparisons
  • Loop forever
  • Increment and decrement operators
  • Assignment operators (e.g. myval += 10)
Other improvements
  • Dynamic menus and web-based windows added
  • Anchors and 'fit component' options for panel objects
  • Group icon contents can be viewed without needing to ungroup
  • User is now warned when openign a project that is already open
  • Flowcode now has separate icons for Embedded, Web Developer and PC Developer project files
  • Macros can now be shown as a different graphical/text view direct from the macro tab
  • Library version log file shows which versions of library files are used in compiled project
  • Colour options available on macro descriptions
  • Position anchors for components
  • New richtext primitive for component panels
  • View group icon contents
  • Access variables in simulated component code
  • Direct access to variable manager
  • Warn when opening a project that is already open
  • New file extensions for Flowcode project types
  • Change macro view types on the fly
  • Advanced component profiling and debugging
  • Clear All Breakpoints no longer ignores the loop command
  • Digital i/o panel now updated correctly when PORT property change iterates through subcomponents
  • Digital i/o panel now updated correctly when pane is first opened
  • Caption bar now shows project type
  • Dropping icons onto overlapped macro views correctly drops onto topmost window
  • Non-flowchart macros can now be exported as image
  • New state diagram macro menu item added
  • Web Developer projects do not show state diagram icons
  • List Occurrences check is now case-insensitive
  • Improvements to dark colour scheme
  • Added ability to show and hide component macros via API command
  • Fixed read-only nature of component properties
  • Fixed the sim control speed slider
  • Fixed 'corrupt macro' error message text that got lost during an exception
  • Mouse events now triggered at the dead area at the top of Project Explorer
  • Component major/minor versions now 0-999 (was 0-100)
  • Hidden option to show '!=' as '<>'
  • Fixed MatrixLight/MatrixDark inbuilt colour schemes for charts
  • 2d panels now hide toolbar when simulating
  • FCDChange event is fired when chip stays the same but clock speed changes
  • Fixed longstanding bug with broadcast message parameter corruption
  • Moved components on 2d panel now redraw their vacated areas too
  • Subcomponents of a group now get unique names when copying/pasting
  • Added GetActual2dPosition/GetActual2dPosition API commands
  • Context menu for component panels stops renames, deletion, etc, when simulating
  • Wndhost comps (button, combobox and textbox) now update when resized on the panel
  • Text primitives now redraw their actual text area too
  • Improved visual styling for dark mode, and fixed styling issues with combo boxes, etc.
  • Removed redundant colour and code-customisation information from saved project files
  • Fixed SIGNED/UNSIGNED casting
  • Fixed simulation of Decision tail icon
  • Search now finds ports/pins
  • Added logical AND, OR and NOT (&&, ||, !) to maths functions list
  • Improved tooltip help for maths and string functions
  • Function lists now categorised
  • Call stack view width can be altered using mouse wheel in Simulation Debugger window
  • Component panel zoom level now shown on status bar
  • Improved component toolbar display on non-100% DPI systems
  • New variables are given default initialisers
  • Macro parameters can have default values for parameters
  • Macro tabs have 'close' and 'close other' menu item
  • Added CallMacro in-built functions
  • Added in-built functions to manipulate text-based property lists
  • Fixed flicker in IOC chip view in interrupt prpoperties dialog
  • Components and macros now available to add to expressions in icon dialogs
  • List properties can now be auto-sorted
  • Flowcode now uses a 'ping' to ensure web-based dialogs retain current information
More details can be found here:
 https://www.flowcode.co.uk/history/FC11_0_0.php
