Component: IrDA (EB012, MCP1250, MCP2120) (Wireless)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.0 |
Category | Wireless |
IrDA (EB012, MCP1250, MCP2120) component
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface.
IrDA Transmit
Receive
Basic example which waits for any incoming data and then displays the data on the LCD.
IrDA Receive
SendChar |
Sends a byte character to the IrDA connection. | |
[[File:]] - | Char |
Return |
ReceiveChar |
Receives byte character from the IrDA connection. | |
[[File:]] - | Timeout |
Max amount of time in milliseconds to wait for data. | |
[[File:]] - | Return |
Initialise |
Initialises the UART ready for IrDA data to be sent or received, | |
Return |
GetTarget |
Gets the target handle the property links to | |
GetState |
Returns true if the button is depressed, else false | |
Register |
Adds the object to the list if not already there | |
[[File:]] - | Target |
Return |
SetLatchingFor |
Sets whether the button is depressed when the mouse is released | |
[[File:]] - | Enabled |
Return |
SetMode |
Sets the animation mode for the button | |
Mode |
0=User, 1=Up/Down, 2 = Lever | |
Return |
SetEnabledPosFor |
Sets the enabled position for an object | |
[[File:]] - | Position |
Return |
SetPivotPosFor |
Sets the position the lever rotates around for an object | |
Return |
SetModeFor |
The target object, 0 for 'set default' | |
Mode |
Return |
SetMovement |
Sets the movement in units or PI/16 steps for the button | |
[[File:]] - | Move |
Movement to set to - default is 4 | |
Return |
SetAxisFor |
Sets the movement axis as an Axis_... constant | |
Axis |
Movement axis to set to, default 4 | |
Return |
SetPivotPos |
Sets the position of the object the lever rotates around | |
[[File:]] - | PositionHandle |
A handle to the position of the depressed location | |
Return |
SetLatching |
Return |
Unregister |
Removes the object to the list if present | |
Return |
SetMovementFor |
Movement to set to, default 4 | |
Return |
CardBitmap |
Displays a monochrome bitmap read from the card on the LCD | |
X |
Range 0-127 | |
Y |
Range 0-31 | |
Filename |
Return |
CardOpen |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
Filename |
Return |
Forwards |
Drives the robot forwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
ReadBearing |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
LCDDrawLine |
Allows a single pixel width line to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ServoAutoMoveToPosition |
Allows one of the servo positions to move gradually to a new position | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
ReadAllValue |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
Return |
LCDBacklight |
Allows the LCD backlight brighntess to be adjusted | |
Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
Return |
LCDDrawRect |
Allows a rectangle to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ReadLine |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
index |
0=Left, 1=Right | |
Return |
ServoDisable |
Allows one of the servo outputs 0-3 to be disabled | |
Channel |
Range 0-3 | |
Return |
ServoEnable |
Allows one of the servo outputs 0-3 to be enabled | |
Channel |
Range 0-3 | |
Return |
CardReadByte |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
Return |
CardErase |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
Filename |
Return |
CardWriteByte |
Appends a byte to the end of the currently open file | |
Data |
Return |
EncoderRead |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
index |
0=Left, 1=Right | |
Return |
SetMotors |
Sets the motor speeds without feedback Range -100 to 100 | |
[[File:]] - | Left |
[[File:]] - | Right |
Return |
Backwards |
Drives the robot backwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
EncoderReset |
Resets the motor encoder counters | |
Return |
LCDVerbose |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
State |
0=Off 1=On | |
Return |
SetProp |
Allows the COM port property to be set from a parent component. | |
PropName |
PropVal |
Return |
CardInit |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
Return |
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
LCDClear |
Clears the LCD | |
Return |
