Author
Matrix Ltd
Version
2.0
Category
Graphical Color
GLCD (ILI9341) component
Graphical display component designed to work with the ILI9341 controller IC Based on the ILI9341 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Please click here to download the component source project: FC_Comp_Source_GLCD_ILI9341.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ILI9341.fcfx
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
LCD_Write_Reg
LCD_Write_Reg
- BYTE
data
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
LCD_Write_Data8
LCD_Write_Data8
- BYTE
data
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
FastPlot
FastPlot
SetDisplayOrientation
- BYTE
Orientation
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
BPlot
- UINT
X1
- UINT
Y1
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Flip X
Flips the horizontal display axis in hardware.
Flip Y
Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
Some display hardware may require colours to be inverted
Swap Red / Blue
Allows Red and Blue colour channels to be swapped to match the way the display has been wired to the controller IC.
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Data Out (MOSI)
Data pin connection
Clock (SCL)
Clock pin connection
Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
Chip select pin connection
Reg Select (D/C)
Reset
Reset pin connection
Use Backlight Pin
LED
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
