Component: TTI Power Supply - PL155-P (TTI PL155-P PSU) (Test Equipment)
Version | 1.0 |
Category | Test Equipment |
TTI Power Supply - PL155-P component
TTI PL155-P Power Supply Unit Component. 15V - 5A
Please click here to download the component source project: FC_Comp_Source_TTIPL155PPSU.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTIPL155PPSU.fcsx
LSE |
Set the value of LSE <n>, Limit Event Status Register <n>, to <nrf>. | |
Register |
Select Register | |
Value |
Value to be placed in the register (0-255) | |
Return |
NOLANOK |
Disables the LAn Err message for no LAN connection found at power on if <nrf> is 1 and enables the message if <nrf> is 0. | |
Status |
0 = Message disabled, 1 = Message enabled | |
Return |
DELTAV |
Set the output <n>voltage step size to <nrf> Volts | |
Output |
Choose Output: 1 = Output 1, 2 = Output 2 (if applicable) | |
Voltage |
Set a Voltage step between 0.0 - 15.0 V | |
Return |
WAI |
Wait for the Operation Complete true. As all commands are completely executed before the next is started this command takes no additional action. | |
Return |
VRet |
Returns the set voltage of output <n> The response is V <n> <nr2><rmt> wjere <nr2> is in Volts. | |
Output |
Return |
DECI |
Decrement the output <n> current limit by the step size set for output <n>. | |
Output |
Return |
SRE |
Set the Service Request Enable Register to <nrf>. | |
Status |
Set register value 0-255 | |
Return |
PRE |
Sets the Parallel Port Enable Register to the value <nrf>. | |
Status |
Return |
DELTAVRet |
Returns the output <n> voltage step size. The response is DELTAV<n><nr2><rmt> where <nr2> is in Volts. | |
Output |
Return |
IRet |
Returns the set current limit of output <n> The response is I <n><nr2><rmt> where <nr2> is in Amps | |
Output |
Return |
RATIORet |
Query the ratio of output 2 (slave) to putput 1 (master) in tracking mode. The response is <nrf>, where <nrf> is the ratio in percent (0 to 100). | |
Return |
ESRRet |
Returns the value in the Standard Event Status Register in <nr1> numeric format. The register is then cleared. The response is <nr1><rmt>. | |
Return |
QERRet |
Query and clear Query Error Register. The response format is nr1<rmt>. | |
Return |
PRERet |
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
Return |
DELTAIRet |
Returns the output <n> current step size. The response is DELTAI<n><nr2><rmt> where <nr2> is in Amps. | |
Output |
Return |
ESERet |
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
Return |
OCPRet |
Returns the current trip setting for output <n> The response is CP<n><nr2><rmt> where <nr2> is in Amps. | |
Output |
Return |
PSUInitialise |
This macro is required to initialise the PSU | |
Return |
OVPRet |
Returns the voltage trip setting for output <n>. The response is VP<n>Mnr2><rmt> where <nr2> is in Volts. | |
Output |
Return |
TRG |
The PSU has no trigger capability. The command is accepted but performs no action. | |
Return |
LSRRet |
Query and clear Limit Event Status Register <n>. The response is <nr1><rmt>. See status reporting section for details. | |
Register |
Select Register number | |
Return |
IORet |
Returns the output readback current for output <n> The response is <nr2>A<rmt> where <nr2> is in Amps. | |
Output |
Return |
INCVV |
Increment the output <n> voltage by the step size for output <n> and verify. | |
Output |
Return |
RATIO |
Set the ratio of output 2 (slave) to output 1 (master) in tracking mode to <nrf>, where <nrf> is the ratio in percent (0 to 100). | |
Ratio |
Ratio percentage (0-100) | |
Return |
OPRet |
Returns output <n> on/off status The response is <nr1><rmt> where 1 = ON, 0 = OFF. | |
Output |
Return |
LSERet |
Return the value of LSE<n>, Limit Status Enable Register <n> - response is <nr1><rmt>. | |
Register |
Select register | |
Return |
DECVV |
Decrement the output <n> voltage by the step size for output <n> and verify. | |
Output |
Return |
VV |
Set output <n> to <nrf> Volts with verify. | |
Output |
Voltage |
Set a Voltage between 0.0 - 15.0 V | |
Return |
V |
Set output <n> to <nrf> Volts | |
Output |
Voltage |
Return |
INCV |
Increment the output <n> voltage by the step size set for output <n>. | |
Output |
Return |
LOCAL |
Go to local. This does not release any active interface lock so that the lock remains with the selected interface when the next remote command is received. | |
Return |
SRERet |
Returns the value of the Service Request Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt> | |
Return |
TRIPRST |
Attempt to clear all trip conditions. | |
Return |
EERRet |
Query and clear Execution Error Register. The response format is nr1 <rmt>. | |
Return |
STBRet |
Returns the value of the Status Byte Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
Return |
ESE |
Sets the Standard Event Status Register to the value of <nrf>. | |
Status |
Set status register to a value of 0-255 | |
Return |
CLS |
Clear Status. Clears the Status structure. This indirectly clears the Status Byte Register. | |
Return |
DECV |
Decrement the output <n> voltage by the step size set for output <n>. | |
Output |
Return |
OP |
Sets the output <n> on/off where <nrf> has the following meaning: 0=OFF, 1=ON. | |
Output |
Status |
0=OFF, 1=ON | |
Return |
ADDRESSRet |
Returns the bus address of the instrument; This is the address used by the GPIB, if fitted, or may be used as a general identifier over the other interfaces. | |
Return |
ISTRet |
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
Return |
OPCRet |
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
Return |
TSTRet |
The PSU has no self test capability and the response is always 0 <rmt>. | |
Return |
VORet |
Returns the output readback voltage for output <n> The response is <nr2>V<rmt> where <nr2> is in Volts. | |
Output |
Return |
IDNRet |
Returns the instrument identification. The exact response is determined by the instrument configuration and is of the form <NAME>, <model>, <Serial No.>, <Version>, <rmt>. | |
Return |
I |
Set output <n> current limit to <nrf> Amps | |
Output |
Current |
Set a current between 0 - 5000 mA | |
Return |
INCI |
Increment the output <n> current limit by the step size set for output <n>. | |
Output |
Return |
LSE |
Register |
Select Register | |
Value |
Return |
NOLANOK |
Status |
Return |
DELTAV |
Output |
Voltage |
Return |
WAI |
Return |
VRet |
Output |
Return |
DECI |
Output |
Return |
SRE |
Status |
Return |
PRE |
Status |
Return |
DELTAVRet |
Output |
Return |
IRet |
Output |
Return |
RATIORet |
Return |
ESRRet |
Return |
QERRet |
Return |
PRERet |
Return |
DELTAIRet |
Output |
Return |
ESERet |
Return |
OCPRet |
Output |
Return |
PSUInitialise |
Return |
OVPRet |
Output |
Return |
TRG |
Return |
LSRRet |
Register |
Return |
IORet |
Output |
Return |
INCVV |
Output |
Return |
RATIO |
Ratio |
Return |
OPRet |
Output |
Return |
LSERet |
Register |
Select register | |
Return |
DECVV |
Output |
Return |
VV |
Output |
Voltage |
Return |
V |
Output |
Voltage |
Return |
INCV |
Output |
Return |
LOCAL |
Return |
SRERet |
Return |
TRIPRST |
Return |
EERRet |
Return |
STBRet |
Return |
ESE |
Status |
Return |
CLS |
Return |
DECV |
Output |
Return |
OP |
Output |
Status |
0=OFF, 1=ON | |
Return |
ADDRESSRet |
Return |
ISTRet |
Return |
OPCRet |
Return |
TSTRet |
Return |
VORet |
Output |
Return |
IDNRet |
Return |
I |
Output |
Current |
Return |
INCI |
Output |
Return |
LSE |
Register |
Select Register | |
Value |
Return |
NOLANOK |
Status |
Return |
DELTAV |
Output |
Voltage |
Return |
WAI |
Return |
VRet |
Output |
Return |
DECI |
Output |
Return |
SRE |
Status |
Return |
PRE |
Status |
Return |
DELTAVRet |
Output |
Return |
IRet |
Output |
Return |
RATIORet |
Return |
ESRRet |
Return |
QERRet |
Return |
PRERet |
Return |
DELTAIRet |
Output |
Return |
ESERet |
Return |
OCPRet |
Output |
Return |
PSUInitialise |
Return |
OVPRet |
Output |
Return |
TRG |
Return |
LSRRet |
Register |
Return |
IORet |
Output |
Return |
INCVV |
Output |
Return |
RATIO |
Ratio |
Return |
OPRet |
Output |
Return |
LSERet |
Register |
Select register | |
Return |
DECVV |
Output |
Return |
VV |
Output |
Voltage |
Return |
V |
Output |
Voltage |
Return |
INCV |
Output |
Return |
LOCAL |
Return |
SRERet |
Return |
TRIPRST |
Return |
EERRet |
Return |
STBRet |
Return |
ESE |
Status |
Return |
CLS |
Return |
DECV |
Output |
Return |
OP |
Output |
Status |
0=OFF, 1=ON | |
Return |
ADDRESSRet |
Return |
ISTRet |
Return |
OPCRet |
Return |
TSTRet |
Return |
VORet |
Output |
Return |
IDNRet |
Return |
I |
Output |
Current |
Return |
INCI |
Output |
Return |
