Author
Matrix Ltd
Version
1.8
Category
Graphical Color
GLCD (SSD1351) component
Graphical display component based on the SSD1251 16-bit colour graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1351.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1351.fcfx
SSD1351 gLCD Example File
SSD1351 Example
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
FastPlot
FastPlot
SendData
SendData
- BYTE
Byte
SetDisplayOrientation
- BYTE
Orientation
BPlot
BPlot
- UINT
X1
- UINT
Y1
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Flip Horizontal
Allows the horizontal axis to be flipped for displays that run right to left.
Flip Vertical
Allows the vertical axis to be flipped for displays that run bottom to top.
Flip Colour
Allows the colour index to be flipped for displays that run blue, green, red.
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Chip select pin connection
Reg Select (RS)
Data (SD)
Serial Clock (SCK)
Reset pin connection
Reset (RST)
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
