Component: Barometer (BMP280 / Grove 101020192) (101020192) (Environmental)
Version | 1.2 |
Category | Environmental |
Barometer (BMP280 / Grove 101020192) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 ?C.
Please click here to download the component source project: FC_Comp_Source_temp/Grove_Barometer_Sensor_BMP280.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Grove_Barometer_Sensor_BMP280.fcfx
Altitude
Altitude |
Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa. | |
Return |
Forced_Read
Forced_Read |
Return |
I2C_Read_Register
I2C_Read_Register |
Reads a byte value from a register on the device | |
Address |
Return |
I2C_Write_Register
I2C_Write_Register |
Writes a byte value to a register on the device | |
Address |
Value |
Return |
Initialise |
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
Return |
ReadPressureFloat
ReadPressureFloat |
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
Return |
ReadTemperatureFloat
Reset
Reset |
Resets the device | |
Return |
