Component: GLCD (SSD1351) (Graphical Color)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.8
Category Graphical Color
GLCD (SSD1351) component
Graphical display component based on the SSD1251 16-bit colour graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1351.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1351.fcfx
SSD1351 gLCD Example File FC6 Icon.png SSD1351 Example Example should show the following on the display on the panel and on the hardware.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
FastPlot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SendCommand
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
SendData
Fc9-comp-macro.png SendData
Fc9-u8-icon.png - BYTE Byte
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Flip Horizontal
Allows the horizontal axis to be flipped for displays that run right to left.
Fc9-type-7-icon.png Flip Vertical
Allows the vertical axis to be flipped for displays that run bottom to top.
Fc9-type-7-icon.png Flip Colour
Allows the colour index to be flipped for displays that run blue, green, red.
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
